Ga door naar hoofdinhoud
Logitech MBJ58 Mouse Support Spring Replacement
Wat je nodig hebt
    1. Logitech MBJ58 Mouse Support Spring Replacement, Top cover: stap 1, afbeelding 1 van 1
      • Hold the mouse so that the bottom is facing up.
      • Remove the single Phillips #1 screw from the bottom half of the mouse.
      Vraag FixBot
      Voeg opmerking toe
    2. Logitech MBJ58 Mouse Support Spring Replacement: stap 2, afbeelding 1 van 2 Logitech MBJ58 Mouse Support Spring Replacement: stap 2, afbeelding 2 van 2
      • Place the mouse so that the bottom is resting against a hard surface.
      • Lift the top cover of the mouse gently, and remove it.
      Vraag FixBot
      Voeg opmerking toe
    1. Logitech MBJ58 Mouse Support Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: stap 3, afbeelding 1 van 3 Logitech MBJ58 Mouse Support Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: stap 3, afbeelding 2 van 3 Logitech MBJ58 Mouse Support Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: stap 3, afbeelding 3 van 3
      • Locate the scroll wheel on the mouse.
      • Grab the scroll wheel with your thumb and index finger.
      • Gently lift up, to remove the scroll wheel from the mouse.
      Vraag FixBot
      Voeg opmerking toe
    1. Logitech MBJ58 Mouse Support Spring Replacement, Support Spring: stap 4, afbeelding 1 van 2 Logitech MBJ58 Mouse Support Spring Replacement, Support Spring: stap 4, afbeelding 2 van 2
      • Locate the spring on the scroll wheel, and carefully remove the spring.
      Vraag FixBot
      Voeg opmerking toe
    2. Logitech MBJ58 Mouse Support Spring Replacement, Attaching the New Spring: stap 5, afbeelding 1 van 2 Logitech MBJ58 Mouse Support Spring Replacement, Attaching the New Spring: stap 5, afbeelding 2 van 2
      • Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
6 andere personen hebben deze handleiding voltooid.
Conor Whatley
510 Reputatie
3 handleidingen geschreven
Cal Poly, Team 5-14, Forte Winter 2013 Lid van Cal Poly, Team 5-14, Forte Winter 2013
CPSU-FORTE-W13S5G14
5 Leden
56 handleidingen geschreven
1Gids Commentaar
The thing with the spring - still in 2024 helpful!
Thanks a lot! :-)
Michaela Meyer - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 79
Altijd: 5,277
