Ga door naar hoofdinhoud
Logitech MBJ58 Mouse Buttons Replacement
Wat je nodig hebt
    1. Logitech MBJ58 Mouse Buttons Replacement, Top cover: stap 1, afbeelding 1 van 1
      • Hold the mouse so that the bottom is facing up.
      • Remove the single Phillips #1 screw from the bottom half of the mouse.
      Vraag FixBot
      Voeg opmerking toe
    2. Logitech MBJ58 Mouse Buttons Replacement: stap 2, afbeelding 1 van 2 Logitech MBJ58 Mouse Buttons Replacement: stap 2, afbeelding 2 van 2
      • Place the mouse so that the bottom is resting against a hard surface.
      • Lift the top cover of the mouse gently, and remove it.
      Vraag FixBot
      Voeg opmerking toe
    1. Logitech MBJ58 Mouse Buttons Replacement, Buttons: stap 3, afbeelding 1 van 2 Logitech MBJ58 Mouse Buttons Replacement, Buttons: stap 3, afbeelding 2 van 2
      • Locate the two tabs that are protruding from the button assembly.
      • Be careful not to break either of the two tabs by squeezing too hard.
      • Pinch the tabs together to free the buttons.
      Vraag FixBot
      Voeg opmerking toe
    2. Logitech MBJ58 Mouse Buttons Replacement: stap 4, afbeelding 1 van 2 Logitech MBJ58 Mouse Buttons Replacement: stap 4, afbeelding 2 van 2
      • Remove the button assembly from the top cover by flipping the top cover upside down and pulling the button assembly downward and away from the top cover.
      • Slide the button assembly out from the top cover through the opening.
      • When fully disassembled, the top cover and the button assembly should look like this.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Maximilian Betkowski
238 Reputatie
4 handleidingen geschreven
Cal Poly, Team 5-14, Forte Winter 2013 Lid van Cal Poly, Team 5-14, Forte Winter 2013
CPSU-FORTE-W13S5G14
5 Leden
56 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 37
Altijd: 3,485
