Ga door naar hoofdinhoud
Logitech MBJ58 Mouse Button Replacement
Wat je nodig hebt
  1. Logitech MBJ58 Mouse Button Replacement, Mouse button: stap 1, afbeelding 1 van 1
    • Unfortunately, the left mouse button was 2x "sucked out" (button & the plastic pin over it)
    • Solution: Swap the button on the left with the mouse wheel button and - n small piece of office clip - for reinforcement - melt into the bottom of the pen.
    • YahooOoO - Looift widerer! Addendum: "mouse wheel click" Works by the way also - because there small springs ensure that the button does not "stick" in the pressed state
    Vraag FixBot
    Voeg opmerking toe
    • Loosen the Phillips screw in the bottom.
    Vraag FixBot
    Voeg opmerking toe
    • The plastic holder of the mouse buttons is loosened by carefully pressing the two plastic closures in the middle.
    • The motherboard is just plugged in and can be carefully removed forwards and upwards.
    Vraag FixBot
    Voeg opmerking toe
    • Sensibly, first clean everything (dry).
    • Now click the button for "Links" with the button below the mouse wheel. The solder joints are huge and easy to get even for beginners.
    Vraag FixBot
    Voeg opmerking toe
    • Everything should click together again and screws can be screwed back in. -> Loooift.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Repeat the steps in reverse order to reassemble your device.
Één andere persoon heeft deze handleiding voltooid.
Met dank aan deze vertalers:
de en
100%
Deze vertalers helpen ons de wereld te repareren! Doe je mee?
Begin met vertalen ›
Tho. Hummet
121 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 37
Altijd: 694
