Ga door naar hoofdinhoud
Logitech M705 Button Failure Fix
Wat je nodig hebt
  1. Logitech M705 Button Failure Fix, Dissassembly and problem identification: stap 1, afbeelding 1 van 2 Logitech M705 Button Failure Fix, Dissassembly and problem identification: stap 1, afbeelding 2 van 2
    • Follow the teardown guide to disassemble the mouse
    • The pad in the upper shell of the mouse that presses on the microswitch has worn , circled red in the photograph. Comapre the wear on this side with the lower level of wear in the equivalent part for the right hand mouse on the left side of the photograph. A close up of the worn part is shown in thhe second photogrpah
    Vraag FixBot
    Voeg opmerking toe
  2. Logitech M705 Button Failure Fix, Use of insulation tape to resolve problem: stap 2, afbeelding 1 van 1
    • Use electrical insulation tape (blue in the photographs) to build up the level of the worn pad. Here I've used four layers
    • Then reassemble the mouse
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To reassemble your device, reverse the dissasembly process as per the Teardown Guide.
Één andere persoon heeft deze handleiding voltooid.
Nick Knows
115 Reputatie
1 Handleiding geschreven
1Gids Commentaar
This fixed an issue for me where the mouse buttons were bouncing (double clicking when trying to hold the button down).
user5219 - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 47
Altijd: 594
