Inleiding
Use this guide to replace the motherboard in your Logitech M215.
Wat je nodig hebt
The battery compartment cover is located on the top of the mouse. The seam running horizontally across the mouse is the top of the cover.
There is a button to pop off the cover. It is located on the bottom of the mouse. you may need to press hard on this button to pop the cover.
If the button does not work, you will need to pry off the cover. You can use your fingernails or a prying tool in order to do this, as seen in the third image.
Remember to insert the new battery in the same orientation as the old one. The positive (plus) end should be facing away from the buttons.
The pads on the underside of the mouse hide the screws. Remove these first. You may need to use your fingernails or a prying tool.
There will be two 0.5mm phillips head screws. Both will be underneath the bottom two pads.
3 andere personen hebben deze handleiding voltooid.
3Gids Commentaar
thanks a lot!
bro whats the next step my guy
