Ga door naar hoofdinhoud
Logitech M100 USB Cable Replacement
Wat je nodig hebt
  1. Logitech M100 USB Cable Replacement, USB Cable: stap 1, afbeelding 1 van 2 Logitech M100 USB Cable Replacement, USB Cable: stap 1, afbeelding 2 van 2
    • Not all variants of this mouse require the mouse feet to be taken off for disassembly, but their removal is detailed anyway.
    • Carefully remove the feet of the mouse with an opening pick.
    • Keep track of the mouse feet, as you'll be reapplying them at the end of the guide.
    Vraag FixBot
    Voeg opmerking toe
  2. Logitech M100 USB Cable Replacement: stap 2, afbeelding 1 van 2 Logitech M100 USB Cable Replacement: stap 2, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver to remove the 10mm screws on the bottom of the mouse.
    • Once all screws are removed, use the plastic opening tool to gently pry the mouse apart. This shouldn't take much force.
    Vraag FixBot
    Voeg opmerking toe
  3. Logitech M100 USB Cable Replacement: stap 3, afbeelding 1 van 2 Logitech M100 USB Cable Replacement: stap 3, afbeelding 2 van 2
    • Once the mouse is opened, locate the USB cable's 5-pin connector, which is plugged directly into the mouse's mainboard.
    • Take note of the position and route that the USB cable takes before removal. The replacement cable must follow the same route when inserted.
    • Using a plastic opening tool, gently remove the 5-pin connector from the mainboard.
    Vraag FixBot
    Voeg opmerking toe
  4. Logitech M100 USB Cable Replacement: stap 4, afbeelding 1 van 2 Logitech M100 USB Cable Replacement: stap 4, afbeelding 2 van 2
    • Take the replacement USB cable and connect it to the mainboard.
    Vraag FixBot
    Voeg opmerking toe
  5. Logitech M100 USB Cable Replacement: stap 5, afbeelding 1 van 2 Logitech M100 USB Cable Replacement: stap 5, afbeelding 2 van 2
    • Ensure that the 5-pin connector is fully seated into its slot on the mainboard. You may want to use a spudger to apply pressure onto it.
    • Using a plastic opening tool, route the cable through the case in the same way that was noted in Step 3.
    Vraag FixBot
    Voeg opmerking toe
  6. Logitech M100 USB Cable Replacement: stap 6, afbeelding 1 van 1
    • After re-assembling the mouse, don't forget to reattach the mouse feet onto their correct locations on the bottom of the mouse.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To reassemble, follow the steps in reverse order.
4 andere personen hebben deze handleiding voltooid.
Jake Janicke
161 Reputatie
1 Handleiding geschreven
1Gids Commentaar
Removing the mouse feet is completely unnecessary, as there are no screws underneath the feet.
Andy Joonseo Bae - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 37
Altijd: 6,546
