Ga door naar hoofdinhoud
Logitech Harmony Ultimate Motherboard Replacement
Wat je nodig hebt
    1. Logitech Harmony Ultimate Motherboard Replacement, Battery: stap 1, afbeelding 1 van 1
      • Remove the single 6 mm Phillips #0 screw located beneath the sticker near the USB charging port.
      Vraag FixBot
      Voeg opmerking toe
    2. Logitech Harmony Ultimate Motherboard Replacement: stap 2, afbeelding 1 van 2 Logitech Harmony Ultimate Motherboard Replacement: stap 2, afbeelding 2 van 2
      • Use a plastic opening tool to release tabs that hold the front panel and back panel together. There are three tabs on each side of the device that need to separate for the device to open.
      • The use of a plastic opening tool is recommended to avoid damaging the remote. Use stronger tools as a last resort.
      • Be careful on the right side (looking at the back side) not to hit the screen ribbon cable. If that is hit and breaks, the touchscreen will not work properly. (example shown in the image)
      Vraag FixBot
      Voeg opmerking toe
    3. Logitech Harmony Ultimate Motherboard Replacement: stap 3, afbeelding 1 van 2 Logitech Harmony Ultimate Motherboard Replacement: stap 3, afbeelding 2 van 2
      • Disconnect the wires running from the back cover to the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    4. Logitech Harmony Ultimate Motherboard Replacement: stap 4, afbeelding 1 van 1
      • Remove the four 6mm Phillips #0 screws from the battery case.
      Vraag FixBot
      Voeg opmerking toe
    5. Logitech Harmony Ultimate Motherboard Replacement: stap 5, afbeelding 1 van 1
      • The battery is still connected to the device via wiring. To free the battery completely, remove the dark plastic piece from the slot with the plastic opening tool. Slowly rotate the dark plastic piece and the battery clockwise until then can be removed from underneath the small circuit board with the USB port.
      • Removing the dark plastic piece from the motherboard takes some patience, as the remote is designed so that the battery will not dislocate under extreme conditions. The small circuit board with the USB port remains connected to the motherboard by six 10 mm pins.
      Vraag FixBot
      Voeg opmerking toe
    6. Logitech Harmony Ultimate Motherboard Replacement: stap 6, afbeelding 1 van 1
      • Lift the battery and its case out of the remote.
      • The battery should still be connected to the case with adhesive.
      Vraag FixBot
      Voeg opmerking toe
    7. Logitech Harmony Ultimate Motherboard Replacement: stap 7, afbeelding 1 van 2 Logitech Harmony Ultimate Motherboard Replacement: stap 7, afbeelding 2 van 2
      • Use the plastic opening tool to separate the battery from the case.
      Vraag FixBot
      Voeg opmerking toe
    1. Logitech Harmony Ultimate Motherboard Replacement, Motherboard: stap 8, afbeelding 1 van 2 Logitech Harmony Ultimate Motherboard Replacement, Motherboard: stap 8, afbeelding 2 van 2
      • Remove the four 6mm Phillips #0 screws from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    2. Logitech Harmony Ultimate Motherboard Replacement: stap 9, afbeelding 1 van 2 Logitech Harmony Ultimate Motherboard Replacement: stap 9, afbeelding 2 van 2
      • There is a flap that connects to the motherboard from the plastic casing. Use fingernails to safely release the flap by flipping the small black buckle upwards.
      • The flap and buckle are underneath the clear yellow piece of tape.
      • Be very careful as damaging this flap could permanently damage your controller.
      Vraag FixBot
      Voeg opmerking toe
    3. Logitech Harmony Ultimate Motherboard Replacement: stap 10, afbeelding 1 van 1
      • The motherboard is now safe to remove by sliding and lifting it backwards out of place.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Aaron Diaz
728 Reputatie
3 handleidingen geschreven
USF Tampa, Team 8-1, Eyestone Fall 2015 Lid van USF Tampa, Team 8-1, Eyestone Fall 2015
USFT-EYESTONE-F15S8G1
5 Leden
19 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 32
Altijd: 2,954
