Ga door naar hoofdinhoud
Logitech Harmony Touch Buttons Replacement
Wat je nodig hebt
  1. Logitech Harmony Touch Buttons Replacement, Buttons: stap 1, afbeelding 1 van 3 Logitech Harmony Touch Buttons Replacement, Buttons: stap 1, afbeelding 2 van 3 Logitech Harmony Touch Buttons Replacement, Buttons: stap 1, afbeelding 3 van 3
    • Open the latch that accesses the charging port.
    • Remove the black sticker and the screw with the Phillips #0 Screwdriver.
    • Take the plastic opening tool and run it down the side of the remote to open the case.
    • While doing this step, three wires connect the two pieces, be sure not to rip them out.
    • Detach the white clamp to disconnect the case from the motherboard partially.
    Vraag FixBot
    Voeg opmerking toe
  2. Logitech Harmony Touch Buttons Replacement: stap 2, afbeelding 1 van 3 Logitech Harmony Touch Buttons Replacement: stap 2, afbeelding 2 van 3 Logitech Harmony Touch Buttons Replacement: stap 2, afbeelding 3 van 3
    • Peel back the thin yellow plastic film.
    • Detach the clip found underneath the film.
    • Remove the screws that connect the motherboard to the case with the Phillips #0 Screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  3. Logitech Harmony Touch Buttons Replacement: stap 3, afbeelding 1 van 3 Logitech Harmony Touch Buttons Replacement: stap 3, afbeelding 2 van 3 Logitech Harmony Touch Buttons Replacement: stap 3, afbeelding 3 van 3
    • Next, carefully remove the motherboard from the top piece of the case.
    • The motherboard is connected to the bottom part of the case.
    • You should now be able to access all the buttons and remove them from the case.
    Vraag FixBot
    Voeg opmerking toe
  4. Logitech Harmony Touch Buttons Replacement: stap 4, afbeelding 1 van 2 Logitech Harmony Touch Buttons Replacement: stap 4, afbeelding 2 van 2
    • Remove the buttons from the case.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Nicholas Townsend
285 Reputatie
2 handleidingen geschreven
USF Tampa, Team S4-G2, Eyestone Fall 2017 Lid van USF Tampa, Team S4-G2, Eyestone Fall 2017
USFT-EYESTONE-F17S4G2
4 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 15
Altijd: 1,907
