Ga door naar hoofdinhoud
Logitech Harmony Smart Control Hub Light Bulb Replacement
Wat je nodig hebt
  1. Logitech Harmony Smart Control Hub Light Bulb Replacement, Light Bulb: stap 1, afbeelding 1 van 2 Logitech Harmony Smart Control Hub Light Bulb Replacement, Light Bulb: stap 1, afbeelding 2 van 2
    • Use a spudger to lift up one of the rubber pads on the bottom of the hub.
    • Pull back the rubber pad and remove it. This will expose the screws on the bottom of the device.
    • Repeat for the second rubber pad.
  2. Logitech Harmony Smart Control Hub Light Bulb Replacement: stap 2, afbeelding 1 van 2 Logitech Harmony Smart Control Hub Light Bulb Replacement: stap 2, afbeelding 2 van 2
    • Use a PH00 screwdriver bit to remove the four 6mm Phillips screws on the bottom of the device.
  3. Logitech Harmony Smart Control Hub Light Bulb Replacement: stap 3, afbeelding 1 van 2 Logitech Harmony Smart Control Hub Light Bulb Replacement: stap 3, afbeelding 2 van 2
    • Use a spudger to separate the top and bottom pieces of the device.
  4. Logitech Harmony Smart Control Hub Light Bulb Replacement: stap 4, afbeelding 1 van 2 Logitech Harmony Smart Control Hub Light Bulb Replacement: stap 4, afbeelding 2 van 2
    • Use the PH00 screwdriver bit to unscrew the three 4mm Phillips screws on the control board.
  5. Logitech Harmony Smart Control Hub Light Bulb Replacement: stap 5, afbeelding 1 van 2 Logitech Harmony Smart Control Hub Light Bulb Replacement: stap 5, afbeelding 2 van 2
    • Place the end of the opening tool under the yellow corner of the circuit board as shown.
    • Gently push upward to pry the board from its housing.
  6. Logitech Harmony Smart Control Hub Light Bulb Replacement: stap 6, afbeelding 1 van 3 Logitech Harmony Smart Control Hub Light Bulb Replacement: stap 6, afbeelding 2 van 3 Logitech Harmony Smart Control Hub Light Bulb Replacement: stap 6, afbeelding 3 van 3
    • Determine which of the five bulbs are defective.
    • Turn the board over to expose the bulb solder.
    • Using a soldering iron, remove the solder and bulb. Replace with a new bulb and re-solder.
Conclusie
Josh Hendricks
464 Reputatie
4 handleidingen geschreven
IUPUI, Team 3-2, Harley Fall 2015 Lid van IUPUI, Team 3-2, Harley Fall 2015
IUPUI-HARLEY-F15S3G2
4 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 9
Altijd: 657
