Ga door naar hoofdinhoud
Logitech Harmony Smart Control Battery Contact Replacement
Wat je nodig hebt
  1. Logitech Harmony Smart Control Battery Contact  Replacement, Battery Contact: stap 1, afbeelding 1 van 2 Logitech Harmony Smart Control Battery Contact  Replacement, Battery Contact: stap 1, afbeelding 2 van 2
    • Use both thumbs to slide the grooved cover off of the remote
    • Once the cover is off, remove the battery.
  2. Logitech Harmony Smart Control Battery Contact  Replacement: stap 2, afbeelding 1 van 2 Logitech Harmony Smart Control Battery Contact  Replacement: stap 2, afbeelding 2 van 2
    • Locate both of the 4mm Phillips screws on the remote. Using the PH00 bit, remove the screws.
  3. Logitech Harmony Smart Control Battery Contact  Replacement: stap 3, afbeelding 1 van 3 Logitech Harmony Smart Control Battery Contact  Replacement: stap 3, afbeelding 2 van 3 Logitech Harmony Smart Control Battery Contact  Replacement: stap 3, afbeelding 3 van 3
    • Use a flat screwdriver or a prying tool to split the remote and separate the two pieces. Start from the bottom.
  4. Logitech Harmony Smart Control Battery Contact  Replacement: stap 4, afbeelding 1 van 2 Logitech Harmony Smart Control Battery Contact  Replacement: stap 4, afbeelding 2 van 2
    • Using the metal piece from the housing, pry the circuit board upwards. Do not disconnect it from the board.
    • Slide the circuit board out from the housing .
  5. Logitech Harmony Smart Control Battery Contact  Replacement: stap 5, afbeelding 1 van 1
    • Locate the battery contacts on the circuit board.
    • Using a soldering iron, remove the old solder and the battery contacts. Install new battery contacts and solder them.
Conclusie
Josh Hendricks
464 Reputatie
4 handleidingen geschreven
IUPUI, Team 3-2, Harley Fall 2015 Lid van IUPUI, Team 3-2, Harley Fall 2015
IUPUI-HARLEY-F15S3G2
4 Leden
5 handleidingen geschreven
1Gids Commentaar
do you know where can i buy the springs?
IOANNIS KARAKOGLOU - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 22
Altijd: 5,161
