Ga door naar hoofdinhoud
Logitech Gamepad F310 Trigger Spring Replacement
Wat je nodig hebt
  1. Logitech Gamepad F310 Trigger Spring Replacement, Case: stap 1, afbeelding 1 van 2 Logitech Gamepad F310 Trigger Spring Replacement, Case: stap 1, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove all seven 3 mm screws that secure the rear case.
    Vraag FixBot
    Voeg opmerking toe
  2. Logitech Gamepad F310 Trigger Spring Replacement: stap 2, afbeelding 1 van 2 Logitech Gamepad F310 Trigger Spring Replacement: stap 2, afbeelding 2 van 2
    • Press along the seams of the controller and gently pull the front and rear case apart.
    • If necessary, use an opening tool to help pry the front and rear case apart.
    • Make sure to open the controller with the front facing down so that the buttons do not fall out.
    Vraag FixBot
    Voeg opmerking toe
  3. Logitech Gamepad F310 Trigger Spring Replacement: stap 3, afbeelding 1 van 1
    • Separate the front and rear case.
    • There are two side panels on the controller that come apart as well. When putting them back together, they slot into place on the sides of the controller.
    Vraag FixBot
    Voeg opmerking toe
  4. Logitech Gamepad F310 Trigger Spring Replacement, Trigger Spring: stap 4, afbeelding 1 van 2 Logitech Gamepad F310 Trigger Spring Replacement, Trigger Spring: stap 4, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove:
    • Four 3 mm screws
    • One 5 mm screw
    • Remove the central silver screw last.
    • Gently lift the motherboard off of the back case and slide the cord out of the top slot.
    Vraag FixBot
    Voeg opmerking toe
  5. Logitech Gamepad F310 Trigger Spring Replacement: stap 5, afbeelding 1 van 1
    • Make note of the slot on the controller and the slot on the trigger that the spring is connected to.
    • Press the trigger down until the spring pops loose.
    • You may need to fish the spring out of the pocket it is in. The spring will be accompanied by a small black piece that fits inside the spring.
    Vraag FixBot
    Voeg opmerking toe
  6. Logitech Gamepad F310 Trigger Spring Replacement: stap 6, afbeelding 1 van 1
    • In order to properly place the spring into the controller, make sure that the black piece is inside, and make sure each end of the spring goes into the correct slots.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
You're all finished! To reassemble your device, follow these instructions carefully in reverse order.
Één andere persoon heeft deze handleiding voltooid.
1Gids Commentaar
I completed this guide in conjunction with this video:
How to disassemble and reassemble the Logitech Gamepad F310
Khalon - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 111
Altijd: 1,621
