Inleiding
This guide will be used to aid you in replacing the Logitech G920 Driving Force steering wheel motherboard. The steering wheel motherboard controls the inputs of all the hardware on the steering wheel, such as the XYAB buttons and D-pad. If your device is having problems related to buttons and paddles not responding, take a look at the troubleshooting guide before continuing with this guide. If you are going to continue with this guide, unplug all parts of the device from any outlets before you start.
Wat je nodig hebt
Use the Phillips #0 screwdriver to remove the five 9.5 mm external screws.
Één andere persoon heeft deze handleiding voltooid.
