Inleiding
This guide will be used to aid you in replacing the Logitech G920 Driving Force D-Pad. The D-pad controls the inputs used to navigate menus. If your device is having problems related to the D-pad not responding, take a look at the troubleshooting guide before continuing with this guide. If you are going to continue with this guide, unplug all parts of the device from any outlets before you start.
Wat je nodig hebt
Use the Phillips #0 screwdriver to remove the five 9.5 mm external screws.
