Ga door naar hoofdinhoud
Logitech G920 Driving Force Steering Wheel D-Pad Replacement
Wat je nodig hebt
  1. Logitech G920 Driving Force Steering Wheel D-Pad Replacement, Steering Wheel Motherboard: stap 1, afbeelding 1 van 1
    • Use the Phillips #0 screwdriver to remove the five 9.5 mm external screws.
    • Only three of the five screws are visible from each side of the wheel due to the center unit.
  2. Logitech G920 Driving Force Steering Wheel D-Pad Replacement: stap 2, afbeelding 1 van 1
    • Using the Phillips #0 screwdriver, remove the 5 mm screws holding the bumpers in place.
  3. Logitech G920 Driving Force Steering Wheel D-Pad Replacement: stap 3, afbeelding 1 van 2 Logitech G920 Driving Force Steering Wheel D-Pad Replacement: stap 3, afbeelding 2 van 2
    • Using the TR25 Torx Security Screwdriver, remove the six 23.8 mm screws holding the face plate together.
    • Remove the face plate from the steering wheel.
  4. Logitech G920 Driving Force Steering Wheel D-Pad Replacement: stap 4, afbeelding 1 van 2 Logitech G920 Driving Force Steering Wheel D-Pad Replacement: stap 4, afbeelding 2 van 2
    • Remove the wheel from the main steering wheel console.
    • Ensure this is done carefully as to not damage the connection wire.
  5. Logitech G920 Driving Force Steering Wheel D-Pad Replacement: stap 5, afbeelding 1 van 2 Logitech G920 Driving Force Steering Wheel D-Pad Replacement: stap 5, afbeelding 2 van 2
    • Remove the eight 7.5 mm screws holding the steering wheel motherboard in place using a Phillips #0 screwdriver.
    • Remove the steering wheel motherboard.
  6. Logitech G920 Driving Force Steering Wheel D-Pad Replacement, Steering Wheel D-Pad: stap 6, afbeelding 1 van 2 Logitech G920 Driving Force Steering Wheel D-Pad Replacement, Steering Wheel D-Pad: stap 6, afbeelding 2 van 2
    • Carefully remove the original D-Pad from the console.
Conclusie
Aiden Muse
477 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 44
Altijd: 211
