Ga door naar hoofdinhoud
Logitech G915 TKL Keyswitch Replacement
Wat je nodig hebt
  1. Logitech G915 TKL Keyswitch Replacement, Keyswitch: stap 1, afbeelding 1 van 2 Logitech G915 TKL Keyswitch Replacement, Keyswitch: stap 1, afbeelding 2 van 2
    • Remove all of the keycaps on the keyboard.
    • Unscrew the 2mm #00 Phillips screws circled in the picture provided.
  2. Logitech G915 TKL Keyswitch Replacement: stap 2, afbeelding 1 van 2 Logitech G915 TKL Keyswitch Replacement: stap 2, afbeelding 2 van 2
    • Turn the keyboard around and peel back the Logitech sticker near the top center of the keyboard, as well as the plastic layer underneath.
    • Unscrew the two 2.5mm #0 Phillips screws circled in the picture provided.
    • Remove the backplate by grabbing the notch to the right and pulling up.
  3. Logitech G915 TKL Keyswitch Replacement: stap 3, afbeelding 1 van 2 Logitech G915 TKL Keyswitch Replacement: stap 3, afbeelding 2 van 2
    • Remove the foam strips shown in the picture provided.
    • Unscrew all the 2mm #00 Phillips screws on the back of the keyboard circled in the picture provided.
  4. Logitech G915 TKL Keyswitch Replacement: stap 4, afbeelding 1 van 1
    • Remove the casing on the keyboard to reveal the motherboard.
  5. Logitech G915 TKL Keyswitch Replacement: stap 5, afbeelding 1 van 1
    • Find the corresponding soldering point for the keyswitch you wish to replace.
  6. Logitech G915 TKL Keyswitch Replacement: stap 6, afbeelding 1 van 1
    • Carefully heat the soldering wire.
    • Place the wire near the keyswitch's solder points so that it can be desoldered by the wire.
    • Insert your new keyswitch in place of the old one.
    • Solder the new keyswitch into place.
Conclusie
Ethan Bedard
485 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 3-6, Petersen Spring 2023 Lid van UMass Dartmouth, Team 3-6, Petersen Spring 2023
UMASSD-PETERSEN-S23S3G6
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 32
Afgelopen 7 dagen: 203
Afgelopen 30 dagen: 949
Altijd: 12,425
