Ga door naar hoofdinhoud
Logitech G733 Battery Replacement
Gearchiveerde handleiding
Deze handleiding wordt enkel nog bijgehouden voor historische doeleinden. Gebruik de laatste versie van deze gids om uw reparatie uit te voeren.
Wat je nodig hebt
  1. Logitech G733 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Before you begin, discharge the headset battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Gently pull the right ear pad off, starting from the top.
    • Slide your finger around the edges until it releases completely.
    • Remove the ear pad.
    Vraag FixBot
    Voeg opmerking toe
  2. Logitech G733 Battery Replacement: stap 2, afbeelding 1 van 2 Logitech G733 Battery Replacement: stap 2, afbeelding 2 van 2
    • Remove the four screws that secure the speaker housing using a Phillips screwdriver.
    • Place these screws on the magnetic pad so you don't lose them.
    Vraag FixBot
    Voeg opmerking toe
  3. Logitech G733 Battery Replacement: stap 3, afbeelding 1 van 3 Logitech G733 Battery Replacement: stap 3, afbeelding 2 van 3 Logitech G733 Battery Replacement: stap 3, afbeelding 3 van 3
    • Lift off the speaker housing with care not to strain the connected cable.
    • Gently wiggle the white battery cable connector side to side while pulling it out to disconnect the battery.
    • Do not pull on the wires.
    Vraag FixBot
    Voeg opmerking toe
  4. Logitech G733 Battery Replacement: stap 4, afbeelding 1 van 1
    • Take care not to puncture, twist, or bend the battery as you pry.
    • Remove the battery, using a spudger to gently pry it up if necessary.
    • Reapply adhesive, put the new battery in place, and plug it in.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To reassemble your device, please follow these instructions in reverse order.
6 andere personen hebben deze handleiding voltooid.
5Gids Commentaar
This guide is great, but mentioning what kind of battery to purchase for the headset would make it infinitely better...
Darbii Rue - Antwoord Deel
I fully agree
Gabriel Nunes - Antwoord Deel
Its a 1.5 phillips on the right side. On the left side its a T5 screw not a T4. And you can easily remove the battery without a spudger. It came out with my bare hands.
Heather Dasher - Antwoord Deel
took 2 mins to find battery info ..........................
Logi 533-000181
Stephen Burrows - Antwoord Deel
after a quick search i bought this and it fit:
https://he.aliexpress.com/item/100500538...
Jad Ghanayem - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 89
Altijd: 17,292
