Inleiding
By following this guide you will be able to remove and replace the quad side button array on your Logitech G700s gaming mouse.
Wat je nodig hebt
Remove the batteries from the mouse.
Use a plastic opening tool to peel up the four mouse feet.
Pull the top of the mouse off of the bottom half.
Unplug the programmable buttons from the motherboard.
Remove the three 5.5mm Phillips #00 screws holding the button assembly to the mouse.
To remove the side button assembly:
First, unhook the cables from the cable guide so it won't get caught while popping the assembly out
The assembly is held in by some clip-in action from the screw posts on the top shell and screw holes on the assembly. The next step will explain in detail how to pop it out.
The screw hole near the left and button side seems to be easier to pop out first. Use thumbnail to pry under the marked location while simultaneously pushing on G7 to pop it out.
Repeat on the other side, pressing on G8.
The assembly should come loose. Push on the buttons and gently wiggle and pull it out.
There will still be a bit of friction between the PCB and the center post on the top shell but it won't take too much force. Try to gently persuade it out.
Één andere persoon heeft deze handleiding voltooid.
3Gids Commentaar
Greetings, Is the quad side button assembly still avail. for replacement?
Doesn't appear when checking the parts item for this replacement build.
Thanks.
Thanks for the instructions.
But If the quad button assembly can not be ordered, doesn't show up for parts, this makes this repair nearly impossible.
