Ga door naar hoofdinhoud
Logitech G502 Lightspeed Switches Replacement
Wat je nodig hebt
  1. Logitech G502 Lightspeed Switches Replacement, Remove skates: stap 1, afbeelding 1 van 1
    • First off, remove the magnetic cover and remove the 3 stock skates. You can reuse them if you pull them off carefully. Logitech skates consist of the actual Teflon skates and a second layer of foamy adhesive. Make sure you pull off both still attached to each other.
    Vraag FixBot
    Voeg opmerking toe
  2. Logitech G502 Lightspeed Switches Replacement, Remove screws: stap 2, afbeelding 1 van 1
    • Remove the 4 screws.
    Vraag FixBot
    Voeg opmerking toe
  3. Logitech G502 Lightspeed Switches Replacement, Open cover: stap 3, afbeelding 1 van 1
    • Start at the back and just clip the whole cover open. Don't be afraid to use a little force. Either use a clipping tool, or just use 3 fingers and your fingernails to grab into the gap and pull it off.
    Vraag FixBot
    Voeg opmerking toe
  4. Logitech G502 Lightspeed Switches Replacement, Detach cables: stap 4, afbeelding 1 van 1
    • Detach both flat cables and the battery connector.
    Vraag FixBot
    Voeg opmerking toe
  5. Logitech G502 Lightspeed Switches Replacement, Remove screws: stap 5, afbeelding 1 van 1
    • Remove these 8 screws.
    Vraag FixBot
    Voeg opmerking toe
  6. Logitech G502 Lightspeed Switches Replacement: stap 6, afbeelding 1 van 2 Logitech G502 Lightspeed Switches Replacement: stap 6, afbeelding 2 van 2
    • Next remove this screw (it's hidden deep, you will need a thin screwdriver to reach it)
    • And this one, This will allow you to remove the top LED cover.
    Vraag FixBot
    Voeg opmerking toe
  7. Logitech G502 Lightspeed Switches Replacement, Remove LED cover: stap 7, afbeelding 1 van 1
    • Remove the LED cover and remove this screw to remove the LED cup.
    Vraag FixBot
    Voeg opmerking toe
  8. Logitech G502 Lightspeed Switches Replacement, Remove screws: stap 8, afbeelding 1 van 1
    • Remove these 4 screws which attach the 2 main buttons to the rest of the module. The right mouse button will fall out, while the left one will stay in place, just put the right one aside for now, you can leave the left one hanging loose. After removing these 4 screws, just pull out the whole internal module.
    Vraag FixBot
    Voeg opmerking toe
  9. Logitech G502 Lightspeed Switches Replacement, Remove buttons: stap 9, afbeelding 1 van 3 Logitech G502 Lightspeed Switches Replacement, Remove buttons: stap 9, afbeelding 2 van 3 Logitech G502 Lightspeed Switches Replacement, Remove buttons: stap 9, afbeelding 3 van 3
    • Remove these 2 screws and remove the 2 top button pieces.
    Vraag FixBot
    Voeg opmerking toe
  10. Logitech G502 Lightspeed Switches Replacement: stap 10, afbeelding 1 van 3 Logitech G502 Lightspeed Switches Replacement: stap 10, afbeelding 2 van 3 Logitech G502 Lightspeed Switches Replacement: stap 10, afbeelding 3 van 3
    • Pull out this plastic bolt which holds the scroll wheel module in place. I suggest you use something sharp to push at the bolt from the one end and pull it with your fingernails from the other side at the same time. It will require some force. After it's out, you can simply lift the whole scroll wheel module off the PCB.
    • When lifting the scroll wheel module, make sure you do not lose the 2 springs!
    Vraag FixBot
    Voeg opmerking toe
  11. Logitech G502 Lightspeed Switches Replacement, Remove screws: stap 11, afbeelding 1 van 1
    • Remove these 2 screws and remove the scroll wheel holder.
    Vraag FixBot
    Voeg opmerking toe
  12. Logitech G502 Lightspeed Switches Replacement, Remove screws: stap 12, afbeelding 1 van 1
    • Remove these 5 screws.
    Vraag FixBot
    Voeg opmerking toe
  13. Logitech G502 Lightspeed Switches Replacement, Solder off switches: stap 13, afbeelding 1 van 3 Logitech G502 Lightspeed Switches Replacement, Solder off switches: stap 13, afbeelding 2 van 3 Logitech G502 Lightspeed Switches Replacement, Solder off switches: stap 13, afbeelding 3 van 3
    • Solder off the Omrons and replace them with switches of your choice.
    Vraag FixBot
    Voeg opmerking toe
  14. Logitech G502 Lightspeed Switches Replacement, Put everything back together: stap 14, afbeelding 1 van 1
    • Put everything back together.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
11 andere personen hebben deze handleiding voltooid.
einself
635 Reputatie
1 Handleiding geschreven
6Gids Commentaar
Thanks for the guide, i used some isopropanol to clean the switches instead of chaning them as i had a problem with the right one and now it works flawless.
Bass pojken XD - Antwoord Deel
Thank you for the guide! I had to replace both my left mouse button and right mouse button switches because of heavy use. I unfortunately de-soldered a bit too hard on my right button switch and had to replace some trace connections but the mouse is working great now! Much appreciated!
Yashin lalji - Antwoord Deel
Thanks so much for the guide; my middle mouse button was no longer giving tactile feedback when I pressed the center wheel. I ended up removing the tactile dome (just the dome and tape) and using one from my old 2011 Ford F-150 key fob works like new.
Mike Morrison - Antwoord Deel
i was able to fix mine by taking it out and flexing it back the right way with a little force, seems to pop back good as new for now
Slushie - Antwoord Deel
thanks for the guide!
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 31
Afgelopen 7 dagen: 256
Afgelopen 30 dagen: 1,267
Altijd: 23,003
