Ga door naar hoofdinhoud
Logitech G305 Scroll Wheel Replacement
Wat je nodig hebt
  1. Logitech G305 Scroll Wheel Replacement, Scroll Wheel: stap 1, afbeelding 1 van 2 Logitech G305 Scroll Wheel Replacement, Scroll Wheel: stap 1, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Flathead 1.5 mm Screwdriver
    $5.49
    • Use a 1.5 mm flathead screwdriver to remove the four mouse skates from the bottom of the mouse.
  2. Logitech G305 Scroll Wheel Replacement: stap 2, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the four bottom case screws.
    • Caution, do not strip the head of the screws. These are not easily replaceable.
  3. Logitech G305 Scroll Wheel Replacement: stap 3, afbeelding 1 van 1
    • Remove the palm cover by simply sliding downwards. Remove the battery and the bluetooth usb.
    • Using a flat head screwdriver 1.5mm to not pry but to adjust the connector. By doing this it will allow you to open the inside.
    • Use caution when raising the outer shell—wires are still connected inside.
  4. Logitech G305 Scroll Wheel Replacement: stap 4, afbeelding 1 van 2 Logitech G305 Scroll Wheel Replacement: stap 4, afbeelding 2 van 2
    • Using the flathead screwdriver 1.5mm you can undo the clip holding the wiring in place.
    These clips can be broken off the board easily due to the small solder connections. Be very careful when undoing them.
    Ffield - Antwoord
  5. Logitech G305 Scroll Wheel Replacement: stap 5, afbeelding 1 van 1
    • There is a metal spring that holds one side of the scroll wheel, remove the metal spring using a flathead screwdriver 1.5mm and lifting the scroll wheel.
  6. Logitech G305 Scroll Wheel Replacement: stap 6, afbeelding 1 van 1
    • Use a Phillips screw driver #00 to remove the four screws.
    • Be careful to not strip the screws, these can't be found at your local hardware store.
  7. Logitech G305 Scroll Wheel Replacement: stap 7, afbeelding 1 van 3 Logitech G305 Scroll Wheel Replacement: stap 7, afbeelding 2 van 3 Logitech G305 Scroll Wheel Replacement: stap 7, afbeelding 3 van 3
    • Using the Flathead screwdriver 1.5mm, disconnect the clip for the green and blue wire.
    • Remove the motherboard out of the casing.
    • The mouse wheel can only come out one way. Slide to the right to release mouse wheel.
Conclusie
9 andere personen hebben deze handleiding voltooid.
Één opmerking
Should you encounter issues with a malfunctioning scroll wheel, consider cleaning it using a can of compressed air and then applying a small amount of PTFE-based multi-use synthetic oil to the scroll wheel housing.
tomzo88 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 17
Afgelopen 7 dagen: 148
Afgelopen 30 dagen: 612
Altijd: 21,702
