Ga door naar hoofdinhoud
Logitech G27 Pedal Spring Replacement
Wat je nodig hebt
  1. Logitech G27 Pedal Spring Replacement, Pedal Spring: stap 1, afbeelding 1 van 1
    • Remove two screws from each pedal with a 2.5mm allen wrench.
    • The left two pedals have 30 mm screws and the right-most pedal has 16.3 mm screws.
    • Once these screws are off, take off the front faces on each pedal, they should be very easy to remove.
    Vraag FixBot
    Voeg opmerking toe
  2. Logitech G27 Pedal Spring Replacement: stap 2, afbeelding 1 van 2 Logitech G27 Pedal Spring Replacement: stap 2, afbeelding 2 van 2
    • Flip over the device. Now remove fourteen 15.8 mm screws from the underside of the pedal assembly with a Phillips #1 screwdriver.
    • There are two of these screws under the carpet grip, make sure you don't miss those!
    • When finished, flip over the device again so that it's in its original position.
    Vraag FixBot
    Voeg opmerking toe
  3. Logitech G27 Pedal Spring Replacement: stap 3, afbeelding 1 van 3 Logitech G27 Pedal Spring Replacement: stap 3, afbeelding 2 van 3 Logitech G27 Pedal Spring Replacement: stap 3, afbeelding 3 van 3
    • Lift the top cover of the device from the front, don't completely remove it yet though, because there are still wires connecting both halves. (NEED PICTURE)
    • Behind the left-most pedal, there are two 7.4mm screws attaching a wire to the top cover. Remove these with a Phillips #1 screwdriver and release the wires.
    • Once the wires are no longer connected to the top cover, remove the cover completely.
    Vraag FixBot
    Voeg opmerking toe
  4. Logitech G27 Pedal Spring Replacement: stap 4, afbeelding 1 van 2 Logitech G27 Pedal Spring Replacement: stap 4, afbeelding 2 van 2
    • Simultaneously remove the 10mm screws connecting the pedal to the red piston behind it.
    • This will take two 2.5mm allen wrenches, one for each side of the screw.
    • Once removed, the piston can rotate free of the pedal.
    Vraag FixBot
    Voeg opmerking toe
  5. Logitech G27 Pedal Spring Replacement: stap 5, afbeelding 1 van 1
    • Flip the piston away from the pedal and remove the top half of it. The spring should now be visible. (NEED PICTURE)
    • Take out the spring, and replace it with a new one.
    • Repeat steps four and five for each pedal that needs a spring replaced.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
10 andere personen hebben deze handleiding voltooid.
Grant Blake
1.782 Reputatie
2 handleidingen geschreven
Cal Poly, Team 15-4, Amido Spring 2015 Lid van Cal Poly, Team 15-4, Amido Spring 2015
CPSU-AMIDO-S15S15G4
4 Leden
25 handleidingen geschreven
6Gids Commentaar
Is it possible to replace / renew the potentiometers used for gas / brake?
Dave Pawson - Antwoord Deel
I replaced the springs and reassembled in reverse order. However, my wheel will no longer power on. Any idea where I would have lost power? Thank you.
matthew.liam.gleason - Antwoord Deel
What size is the cluch spring
isaacjohnson138 - Antwoord Deel
6cm length
2cm diameter
hermimaier - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 114
Altijd: 23,243
