Ga door naar hoofdinhoud
Logitech G27 C-Clamp Replacement
Wat je nodig hebt
  1. Logitech G27 C-Clamp  Replacement, Steering Wheel: stap 1, afbeelding 1 van 1
    • Remove the six gray 25mm hex screws with a 4mm allen wrench.
    • Watch out when you lift the wheel up, as there are fragile wires connected to the bottom side.
    • Carefully lift up the wheel, but do not disconnect it from the rest of the device.
    Vraag FixBot
    Voeg opmerking toe
  2. Logitech G27 C-Clamp  Replacement: stap 2, afbeelding 1 van 1
    • Carefully lift the wheel off of the hub, exposing the 2 shifter paddle wires and PCB board.
    Vraag FixBot
    Voeg opmerking toe
  3. Logitech G27 C-Clamp  Replacement: stap 3, afbeelding 1 van 1
    • Remove the two 7.5 mm silver screws holding the green PCB board in the wheel with a Phillips #1 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  4. Logitech G27 C-Clamp  Replacement: stap 4, afbeelding 1 van 1
    • Carefully remove the PCB board from the wheel hub.
    Vraag FixBot
    Voeg opmerking toe
  5. Logitech G27 C-Clamp  Replacement: stap 5, afbeelding 1 van 1
    • Carefully pinch and unplug the large 7-pin connector under the PCB board.
    • Be careful when unplugging this adapter, try not to pull on the wires to avoid damaging them. Instead, wiggle around the plastic connector while pulling on it to loosen it.
    Vraag FixBot
    Voeg opmerking toe
  6. Logitech G27 C-Clamp  Replacement: stap 6, afbeelding 1 van 1
    • You can now fully remove the wheel from the hub. Set it aside until you put the wheel back together.
    • Remove the innermost three 37.5mm silver screws with a Phillips #2 screwdriver.
    • Remove the wheel hub and push the connector through the center of the hub.
    Vraag FixBot
    Voeg opmerking toe
  7. Logitech G27 C-Clamp  Replacement: stap 7, afbeelding 1 van 1
    • The wheel hub can now be set aside and flip over the steering wheel housing to reveal the under side.
    • Remove the eight 15.9mm silver surrounding screws underneath the wheel housing with a Phillips #1 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  8. Logitech G27 C-Clamp  Replacement: stap 8, afbeelding 1 van 1
    • Rotate the housing back over and remove the top half of the housing revealing the majority of the components of the wheel.
    • The housing cover can be set aside until you put the wheel back together.
    Vraag FixBot
    Voeg opmerking toe
  9. Logitech G27 C-Clamp  Replacement: stap 9, afbeelding 1 van 1
    • Remove the four 7.3mm silver screws attaching the green PCB board to the motor housing with a Phillips #2 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  10. Logitech G27 C-Clamp  Replacement: stap 10, afbeelding 1 van 1
    • Unplug the three plastic connectors on the left side of the PCB board.
    • Unplug the two plastic connectors on the top of the PCB board.
    • Unplug the three plastic connectors on the right side of the PCB board.
    • Pulling the plastic connectors requires a lot of force, but be careful and don't pull directly on the wires. Try to wedge or push the male side of the connector out.
    • If you need some extra leverage when removing these connectors, try using a plastic opening tool to pry off the connectors.
    • Removing these connectors allows easier access to the four screws attaching the PCB board mount to the motor housing.
    Vraag FixBot
    Voeg opmerking toe
  11. Logitech G27 C-Clamp  Replacement: stap 11, afbeelding 1 van 1
    • Remove the PCB board after all of the plastic connectors are disconnected.
    • You can now set it aside.
    Vraag FixBot
    Voeg opmerking toe
  12. Logitech G27 C-Clamp  Replacement: stap 12, afbeelding 1 van 1
    • Remove the two 12.3mm upper black screws with a Phillips #2 screwdriver.
    • Remove the two 15.5mm bottom silver screws with a Phillips #1 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  13. Logitech G27 C-Clamp  Replacement: stap 13, afbeelding 1 van 2 Logitech G27 C-Clamp  Replacement: stap 13, afbeelding 2 van 2
    • Remove the PCB board mount and remove the clear plastic piece underneath.
    • Set them aside until you reassemble the wheel.
    Vraag FixBot
    Voeg opmerking toe
  14. Logitech G27 C-Clamp  Replacement, C-Clamp: stap 14, afbeelding 1 van 1
    • Unscrew the piece holding the C-Clamp in place with your hand.
    Vraag FixBot
    Voeg opmerking toe
  15. Logitech G27 C-Clamp  Replacement: stap 15, afbeelding 1 van 2 Logitech G27 C-Clamp  Replacement: stap 15, afbeelding 2 van 2
    • Push the remaining nob forward and then inward through the slot.
    Vraag FixBot
    Voeg opmerking toe
  16. Logitech G27 C-Clamp  Replacement: stap 16, afbeelding 1 van 2 Logitech G27 C-Clamp  Replacement: stap 16, afbeelding 2 van 2
    • The C-Clamp can now be easily pulled out of the bottom of the device.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
24 andere personen hebben deze handleiding voltooid.
Daniel Louis
758 Reputatie
1 Handleiding geschreven
Cal Poly, Team 15-4, Amido Spring 2015 Lid van Cal Poly, Team 15-4, Amido Spring 2015
CPSU-AMIDO-S15S15G4
4 Leden
25 handleidingen geschreven
15Gids Commentaar
Where would I buy the replacement C-Clamps from because one of mine are broken and I need to install a new one.
Mumin Mazhar - Antwoord Deel
Look for it at eBay.
Eduardo - Antwoord Deel
I also need to find a place to buy replacement C-clamps from
hockeyjockone - Antwoord Deel
Can you tell me where I can buy these clamps?
kholiwen - Antwoord Deel
step 9 to 13 not needed ... please confirm
Matt Na - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 32
Afgelopen 30 dagen: 128
Altijd: 50,403
