Ga door naar hoofdinhoud
Logitech G Cloud L2-R2 Trigger Replacement
Wat je nodig hebt
  1. Logitech G Cloud L2-R2 Trigger Replacement, Case: stap 1, afbeelding 1 van 2 Logitech G Cloud L2-R2 Trigger Replacement, Case: stap 1, afbeelding 2 van 2
    • Power the device off and turn it over so the screen is face down.
    • Insert an opening pick into the seam between the back plate and left handguard.
    • Pry around the entire perimeter until the handguard fully releases.
    • Remove the handguard.
    • Repeat the previous three bullets on the right handguard.
    Vraag FixBot
    Voeg opmerking toe
  2. Logitech G Cloud L2-R2 Trigger Replacement: stap 2, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove all eight 10 mm screws from the rear case located under where the handguards were.
    Vraag FixBot
    Voeg opmerking toe
  3. Logitech G Cloud L2-R2 Trigger Replacement: stap 3, afbeelding 1 van 2 Logitech G Cloud L2-R2 Trigger Replacement: stap 3, afbeelding 2 van 2
    • Insert an opening pick into the seam between the midframe and rear case.
    • Gently pry the rear case upwards to separate it from the midframe.
    Vraag FixBot
    Voeg opmerking toe
  4. Logitech G Cloud L2-R2 Trigger Replacement: stap 4, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove all seven 10 mm screws that secure the midframe.
    Vraag FixBot
    Voeg opmerking toe
  5. Logitech G Cloud L2-R2 Trigger Replacement: stap 5, afbeelding 1 van 2 Logitech G Cloud L2-R2 Trigger Replacement: stap 5, afbeelding 2 van 2
    • Insert an opening pick into the seam between the midframe and front case at the top of the device to separate the interior plating.
    • Gently pry out the midframe by lifting an opening pick.
    • You may hear loud popping noises when you remove the interior plating. That's the sound of the retaining clips disengaging.
    Vraag FixBot
    Voeg opmerking toe
  6. Logitech G Cloud L2-R2 Trigger Replacement, L2-R2 Trigger: stap 6, afbeelding 1 van 2 Logitech G Cloud L2-R2 Trigger Replacement, L2-R2 Trigger: stap 6, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove all four 10 mm screws that secure the L2 and R2 triggers.
    • Pop the L2 and R2 triggers out with your fingers.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 66
Altijd: 625
