Ga door naar hoofdinhoud
Logitech Circle Ribbon Cable Replacement
Wat je nodig hebt
  1. Logitech Circle Ribbon Cable Replacement, Ribbon Cable: stap 1, afbeelding 1 van 2 Logitech Circle Ribbon Cable Replacement, Ribbon Cable: stap 1, afbeelding 2 van 2
    • Wedge the plastic opening tool under the black circle lens and gently pry it off.
    • The lens is only attached with sticky tape and should remove relatively easily.
    Vraag FixBot
    Voeg opmerking toe
  2. Logitech Circle Ribbon Cable Replacement: stap 2, afbeelding 1 van 2 Logitech Circle Ribbon Cable Replacement: stap 2, afbeelding 2 van 2
    • Remove the four 3mm Phillips #0 screws that hold down the first ring.
    Vraag FixBot
    Voeg opmerking toe
  3. Logitech Circle Ribbon Cable Replacement: stap 3, afbeelding 1 van 2 Logitech Circle Ribbon Cable Replacement: stap 3, afbeelding 2 van 2
    • Remove the four 3mm Phillips #0 screws that hold down the second ring.
    Vraag FixBot
    Voeg opmerking toe
  4. Logitech Circle Ribbon Cable Replacement: stap 4, afbeelding 1 van 2 Logitech Circle Ribbon Cable Replacement: stap 4, afbeelding 2 van 2
    • Remove the four 3mm Phillips #0 screws that hold down the final ring. Do not remove the lens/battery bundle yet.
    • The lens/battery bundle is attached to the base by a ribbon cable that can break, so be very careful handling the circle.
    Vraag FixBot
    Voeg opmerking toe
  5. Logitech Circle Ribbon Cable Replacement: stap 5, afbeelding 1 van 2 Logitech Circle Ribbon Cable Replacement: stap 5, afbeelding 2 van 2
    • Gently remove the lens/battery bundle from the base of the circle, being mindful of the ribbon cable.
    Vraag FixBot
    Voeg opmerking toe
  6. Logitech Circle Ribbon Cable Replacement: stap 6, afbeelding 1 van 2 Logitech Circle Ribbon Cable Replacement: stap 6, afbeelding 2 van 2
    • Gently pull the ribbon cable loose from the lens/battery bundle.
    • While this is not an entirely necessary step, it helps to ensure the ribbon cable will not break during the rest of the replacement.
    Vraag FixBot
    Voeg opmerking toe
  7. Logitech Circle Ribbon Cable Replacement: stap 7, afbeelding 1 van 3 Logitech Circle Ribbon Cable Replacement: stap 7, afbeelding 2 van 3 Logitech Circle Ribbon Cable Replacement: stap 7, afbeelding 3 van 3
    • Once the old ribbon cable has been detached from the lens/battery bundle it's time to release the other side from the base.
    • Locate the screws holding the base together by feeling for the soft spots underneath the manufacturer's sticker. Punch through with your screwdriver and remove the three 3mm Phillips #0 screws.
    • The two pieces of the base can now be easily pulled apart.
    Vraag FixBot
    Voeg opmerking toe
  8. Logitech Circle Ribbon Cable Replacement: stap 8, afbeelding 1 van 2 Logitech Circle Ribbon Cable Replacement: stap 8, afbeelding 2 van 2
    • Gently pull the ribbon cable loose from its connection to the base.
    Vraag FixBot
    Voeg opmerking toe
  9. Logitech Circle Ribbon Cable Replacement: stap 9, afbeelding 1 van 2 Logitech Circle Ribbon Cable Replacement: stap 9, afbeelding 2 van 2
    • Slide the push pin holding the plastic connector/ribbon cable in place out on both sides.
    Vraag FixBot
    Voeg opmerking toe
  10. Logitech Circle Ribbon Cable Replacement: stap 10, afbeelding 1 van 1
    • Remove the black plastic connector and the two springs from the base of the device.
    Vraag FixBot
    Voeg opmerking toe
  11. Logitech Circle Ribbon Cable Replacement: stap 11, afbeelding 1 van 1
    • Reach inside the circle and pull the ribbon cable free from the device.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Haley Williams
112 Reputatie
1 Handleiding geschreven
6Gids Commentaar
where can I buy such a cable?
kersop@gmail.com
Nico Kersop - Antwoord Deel
The cable I received from China is not the right one. Where do you buy the correct one?
Helen - Antwoord Deel
Can you advise where to buy the correct cable?
Michele Ingratta - Antwoord Deel
I have cable has beark off. I need that cable.
Where can I find
Alican Döşlü - Antwoord Deel
i also need that cable
l_samin - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 41
Altijd: 2,722
