Ga door naar hoofdinhoud
Logitech Circle Battery Replacement
Wat je nodig hebt
  1. Logitech Circle Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Logitech Circle Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Wedge the plastic opening tool under the black circle lens to gently pry it off.
    • The lens is only attached with sticky tape and should remove relatively easily.
    Vraag FixBot
    Voeg opmerking toe
  2. Logitech Circle Battery Replacement: stap 2, afbeelding 1 van 1
    • Remove the four 3mm Phillips #0 screws that hold down the first ring.
    Vraag FixBot
    Voeg opmerking toe
  3. Logitech Circle Battery Replacement: stap 3, afbeelding 1 van 2 Logitech Circle Battery Replacement: stap 3, afbeelding 2 van 2
    • Remove the four 3mm Phillips #0 screws that hold down the second ring.
    Vraag FixBot
    Voeg opmerking toe
  4. Logitech Circle Battery Replacement: stap 4, afbeelding 1 van 2 Logitech Circle Battery Replacement: stap 4, afbeelding 2 van 2
    • Remove the four 3mm Phillips #0 screws that hold down the final ring. Do not remove the lens/battery bundle yet.
    • The lens/battery bundle is attached to the base by a ribbon cable that can break, so be very careful handling the circle.
    Vraag FixBot
    Voeg opmerking toe
  5. Logitech Circle Battery Replacement: stap 5, afbeelding 1 van 2 Logitech Circle Battery Replacement: stap 5, afbeelding 2 van 2
    • Gently remove the lens/battery bundle from the base of the circle, being mindful of the ribbon cable.
    Vraag FixBot
    Voeg opmerking toe
  6. Logitech Circle Battery Replacement: stap 6, afbeelding 1 van 2 Logitech Circle Battery Replacement: stap 6, afbeelding 2 van 2
    • Gently pull the ribbon cable loose from the lens/battery bundle.
    • While this is not an entirely necessary step, it helps to ensure the ribbon cable will not break during the rest of the battery replacement.
    Vraag FixBot
    Voeg opmerking toe
  7. Logitech Circle Battery Replacement: stap 7, afbeelding 1 van 1
    • Carefully unplug the battery from the rest of the lens.
    Vraag FixBot
    Voeg opmerking toe
  8. Logitech Circle Battery Replacement: stap 8, afbeelding 1 van 1
    • Remove the battery using a plastic opening tool. The battery is attached with sticky tape and will remove with gentle prying motions.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
6 andere personen hebben deze handleiding voltooid.
Kylie
348 Reputatie
1 Handleiding geschreven
21Gids Commentaar
What about circle wireless batter with the unscrewBle lens? I keep getting error in set up that the battery is too low to proceed.
I charged only the battery portion all day. Stil. Same results
Diane Fischer - Antwoord Deel
Did you figure out the battery?
Mike Arango - Antwoord Deel
Where did you buy the battery? I can’t find something to replace it with :(
Razvan Ciocanel - Antwoord Deel
I measured my battery and it is 40mm x 14mm x 30mm. The space for the battery looks like I can fit something as long as 45mm. I can not find anything in the US. Going to try these: https://www.ebay.com/itm/3-7V-1200mAh-10.... Pretty annoying that I can not find something to drop in. The most challenging part of this repair is going to be wiring these two Lipos together properly. Does anyone know the voltage of the 3 wires? My battery is completely dead so I cannot get a voltage reading. I am going to have to plug the camera in, plug the battery connector in and get the voltage from there :)
Jonathan Flower - Antwoord Deel
Hey, did you manage to make this work? I want to order some battery and try the same thing. I understand that you need 2 from the pictures. How are they tied together? You can not see that from this tutorial.
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 29
Afgelopen 30 dagen: 99
Altijd: 12,773
