Ga door naar hoofdinhoud
Little Tikes Tobi 2 Interactive Karaoke Machine Case Replacement
Wat je nodig hebt
  1. Little Tikes Tobi 2 Interactive Karaoke Machine Case Replacement, Battery: stap 1, afbeelding 1 van 3 Little Tikes Tobi 2 Interactive Karaoke Machine Case Replacement, Battery: stap 1, afbeelding 2 van 3 Little Tikes Tobi 2 Interactive Karaoke Machine Case Replacement, Battery: stap 1, afbeelding 3 van 3
    • Use a Phillips screwdriver to remove the single screw that is holding the cover to the battery compartment.
    • If the screw doesn’t come out right away, use a spudger to gently lift the edge of the battery compartment in the recessed area while continuing to unscrew it with your other hand.
    • Use a spudger to carefully pry off the battery cover.
  2. Little Tikes Tobi 2 Interactive Karaoke Machine Case Replacement: stap 2, afbeelding 1 van 2 Little Tikes Tobi 2 Interactive Karaoke Machine Case Replacement: stap 2, afbeelding 2 van 2
    • To easily pop out a battery, use your thumb to push the battery from the flat side down toward the coil and pull the battery outward.
    • Remove all four batteries.
    • Take a new AA alkaline battery and position it in the correct orientation. Insert the flat side of the battery facing the coil first, then press the raised side down. Ensure this second battery is oriented in the opposite direction to the first. Continue replacing the batteries in an alternating pattern.
  3. Little Tikes Tobi 2 Interactive Karaoke Machine Case Replacement, Case: stap 3, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove four screws from the base of the device.
    • If the screws don't come out, you can gently lift them with the screwdriver tip or push them out from the other side once they're all loosened.
    • Remove the bottom of the karaoke machine.
    • Don't pull it apart roughly as it is attached to internal cables and they may be damaged in the process.
  4. Little Tikes Tobi 2 Interactive Karaoke Machine Case Replacement: stap 4, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the four screws from the interior of the white base.
  5. Little Tikes Tobi 2 Interactive Karaoke Machine Case Replacement: stap 5, afbeelding 1 van 2 Little Tikes Tobi 2 Interactive Karaoke Machine Case Replacement: stap 5, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the four screws from the exterior black plastic part of the case.
    • Use a spudger to disassemble the case.
Conclusie
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Isaiah Eagle
607 Reputatie
5 handleidingen geschreven
CSU Los Angeles, Team 5-4, Kershman Fall 2024 Lid van CSU Los Angeles, Team 5-4, Kershman Fall 2024
CSULA-KERSHMAN-F24S5G4
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 28
Altijd: 45
