Ga door naar hoofdinhoud
Linksys WRT54G Motherboard Replacement
Wat je nodig hebt
  1. Linksys WRT54G Motherboard Replacement, Antennas: stap 1, afbeelding 1 van 1
    • Unfold the antennas straight away from the device.
  2. Linksys WRT54G Motherboard Replacement: stap 2, afbeelding 1 van 3 Linksys WRT54G Motherboard Replacement: stap 2, afbeelding 2 van 3 Linksys WRT54G Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Remove the black caps from the antennas by pulling them away from the device.
  3. Linksys WRT54G Motherboard Replacement: stap 3, afbeelding 1 van 3 Linksys WRT54G Motherboard Replacement: stap 3, afbeelding 2 van 3 Linksys WRT54G Motherboard Replacement: stap 3, afbeelding 3 van 3
    • Unscrew each of the antennas from the wireless device.
  4. Linksys WRT54G Motherboard Replacement, Casing: stap 4, afbeelding 1 van 2 Linksys WRT54G Motherboard Replacement, Casing: stap 4, afbeelding 2 van 2
    • Using a bit of force, remove the blue plastic case.
  5. Linksys WRT54G Motherboard Replacement, Motherboard: stap 5, afbeelding 1 van 2 Linksys WRT54G Motherboard Replacement, Motherboard: stap 5, afbeelding 2 van 2
    • To remove the black casing that surrounds the green motherboard, slide the top half of the casing backwards. It only moves a very short distance.
    • Pull the top piece upwards and away from the bottom to remove.
  6. Linksys WRT54G Motherboard Replacement: stap 6, afbeelding 1 van 2 Linksys WRT54G Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Locate the 2 M2.5x6mm screws that attach the motherboard to the back case.
    • Remove the two screws from the motherboard as indicated with the Phillips head screwdriver.
  7. Linksys WRT54G Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Once screws have been removed, slide the motherboard in the direction of its LED lights.
    • Lift motherboard up and away from the black lower casing.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Aaron Brown
163 Reputatie
2 handleidingen geschreven
Cal Poly, Team 17-7, Regan Fall 2011 Lid van Cal Poly, Team 17-7, Regan Fall 2011
CPSU-REGAN-F11S17G7
4 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 3,382
