Inleiding
Without a working reset button, users will not be able to default the router to factory settings. Resetting the router allows users to access the router in case they forget the password to the router administrator settings page or Wi-Fi network.
This guide will show users step by step instructions on accessing the router motherboard to replace the router reset button.
Wat je nodig hebt
Gereedschap gebruikt in deze stap:Tweezers$4.99
Remove the antennas by unscrewing them from the base.
Flip over the device and locate the four rubber feet on the bottom.
Remove the rubber feet with tweezers
Make sure to correctly identify the red router reset button.
Locate the four solder points on the other side of the motherboard.
4 andere personen hebben deze handleiding voltooid.
