Ga door naar hoofdinhoud
Lexibook Junior Tablet Headphone Jack Replacement
Wat je nodig hebt
  1. Lexibook Junior Tablet Headphone Jack Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure your device is powered off before replacement to prevent electric shock.
    • With the device screen face down, use the metal spudger to remove the small rubber circles on all four corners of the device. The screws should now be revealed.
    • Using the metal spudger, pry open the small, long rubber rectangle on the back of the device to reveal more screws.
  2. Lexibook Junior Tablet Headphone Jack Replacement: stap 2, afbeelding 1 van 1
    • Using a Phillips #00 screwdriver, remove the four 6.8mm screws from the four corners of the device.
    • Using the same screwdriver, remove the three screws that were behind the rubber rectangle. These screws do not come out of the device.
    • Use the plastic opening tool to gently pry open the back panel of the tablet.
  3. Lexibook Junior Tablet Headphone Jack Replacement: stap 3, afbeelding 1 van 1
    • Use the nylon spudger to gently pry under the battery to remove it.
    • Make sure you do not damage the battery or metal plate in this process and only use a nylon spudger. Be patient and work slowly for the best results.
  4. Lexibook Junior Tablet Headphone Jack Replacement: stap 4, afbeelding 1 van 1
    • Use a soldering iron to remove the battery from the motherboard safely.
    • For advice on how to solder, check out iFixit's Soldering Guide.
  5. Lexibook Junior Tablet Headphone Jack Replacement, Motherboard: stap 5, afbeelding 1 van 2 Lexibook Junior Tablet Headphone Jack Replacement, Motherboard: stap 5, afbeelding 2 van 2
    • Using the plastic opening tool, gently push the two small, black and white switches out in the direction of the ribbon wires.
    • Slowly pull the ribbon wire out of the switch to free it.
  6. Lexibook Junior Tablet Headphone Jack Replacement: stap 6, afbeelding 1 van 1
    • Push the larger black and white strip leading to a ribbon wire upward using the plastic opening tool.
    • Carefully pull the ribbon wire out of the switch
  7. Lexibook Junior Tablet Headphone Jack Replacement: stap 7, afbeelding 1 van 3 Lexibook Junior Tablet Headphone Jack Replacement: stap 7, afbeelding 2 van 3 Lexibook Junior Tablet Headphone Jack Replacement: stap 7, afbeelding 3 van 3
    • Unscrew the five 4 mm screws around the perimeter of the motherboard using the ph00 size phillips head screwdriver.
  8. Lexibook Junior Tablet Headphone Jack Replacement: stap 8, afbeelding 1 van 2 Lexibook Junior Tablet Headphone Jack Replacement: stap 8, afbeelding 2 van 2
    • Remove the button board by unscrewing two more 4 mm screws and one 6.5 mm screw
  9. Lexibook Junior Tablet Headphone Jack Replacement: stap 9, afbeelding 1 van 1
    • Solder off connections from the wire connecting the motherboard to the speaker.
    • For how to solder, check out iFixit's Soldering Guide.
  10. Lexibook Junior Tablet Headphone Jack Replacement, Headphone Jack: stap 10, afbeelding 1 van 1
    • Peel back the yellow film on top of the headphone jack.
  11. Lexibook Junior Tablet Headphone Jack Replacement: stap 11, afbeelding 1 van 1
Conclusie
Rachel Klesius
645 Reputatie
6 handleidingen geschreven
USF Tampa, Team 17-3, Blackwell Fall 2016 Lid van USF Tampa, Team 17-3, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G3
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 170
