Ga door naar hoofdinhoud
Levoit Core 300-RAC Control Board Replacement
Wat je nodig hebt
    1. Levoit Core 300-RAC Control Board Replacement, Control Board: stap 1, afbeelding 1 van 3 Levoit Core 300-RAC Control Board Replacement, Control Board: stap 1, afbeelding 2 van 3 Levoit Core 300-RAC Control Board Replacement, Control Board: stap 1, afbeelding 3 van 3
      • Make sure the device is turned off and unplugged before disassembling it.
      • Insert the Jimmy between the gray grille cover and the top of the device.
      • Work your way around the grille cover with the Jimmy to release the clips holding it in place.
      • Take note of the placement of the clips, as they are keyed and need to go back in the exact way they came out.
      • Remove the grille cover gently as it is connected by a ribbon cable.
      • Be careful not to put too much strain on the ribbon cable as it may break.
      Vraag FixBot
      Voeg opmerking toe
    2. Levoit Core 300-RAC Control Board Replacement: stap 2, afbeelding 1 van 3 Levoit Core 300-RAC Control Board Replacement: stap 2, afbeelding 2 van 3 Levoit Core 300-RAC Control Board Replacement: stap 2, afbeelding 3 van 3
      • Squeeze the tab on the connector to release the bundled cable from the control board.
      • The connector should come out fairly easily, so do not force it. Pulling too hard could damage the connector.
      Vraag FixBot
      Voeg opmerking toe
    3. Levoit Core 300-RAC Control Board Replacement: stap 3, afbeelding 1 van 2 Levoit Core 300-RAC Control Board Replacement: stap 3, afbeelding 2 van 2
      • Gently bend the gray plastic cover to release the control board.
      • There are several hard tabs holding the control board in place.
      Vraag FixBot
      Voeg opmerking toe
    4. Levoit Core 300-RAC Control Board Replacement: stap 4, afbeelding 1 van 3 Levoit Core 300-RAC Control Board Replacement: stap 4, afbeelding 2 van 3 Levoit Core 300-RAC Control Board Replacement: stap 4, afbeelding 3 van 3
      • Lift the control board from the gray plastic cover.
      • Take note of the orientations of the buttons, as that will help during reassembly.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Mustafa
259 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 1-6, Petersen Fall 2023 Lid van UMass Dartmouth, Team 1-6, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G6
5 Leden
8 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 27
Afgelopen 30 dagen: 90
Altijd: 1,895
