Ga door naar hoofdinhoud
Lenovo Y50 Touch RAM Replacement
Wat je nodig hebt
  1. Lenovo Y50 Touch RAM Replacement, RAM: stap 1, afbeelding 1 van 2 Lenovo Y50 Touch RAM Replacement, RAM: stap 1, afbeelding 2 van 2
    • Place laptop on a flat surface with the back cover facing up.
    • Remove all twelve 6 mm long screws on the back of the laptop using a Phillips #1 screwdriver.
    • Apply a lot of pressure to prevent the screws from stripping.
    Vraag FixBot
    Voeg opmerking toe
  2. Lenovo Y50 Touch RAM Replacement: stap 2, afbeelding 1 van 2 Lenovo Y50 Touch RAM Replacement: stap 2, afbeelding 2 van 2
    • Gently pull off the back cover of the laptop. It should come off easily.
    Vraag FixBot
    Voeg opmerking toe
  3. Lenovo Y50 Touch RAM Replacement, Locate the RAM: stap 3, afbeelding 1 van 1
    • The RAM should be located at the indicated area inside the laptop.
    Vraag FixBot
    Voeg opmerking toe
  4. Lenovo Y50 Touch RAM Replacement, Unclamp the RAM: stap 4, afbeelding 1 van 2 Lenovo Y50 Touch RAM Replacement, Unclamp the RAM: stap 4, afbeelding 2 van 2
    • Release the clamps securing the RAM by pushing each clamp away from the RAM.
    • Once the clamps are released, the RAM should be facing outward at an angle.
    Vraag FixBot
    Voeg opmerking toe
  5. Lenovo Y50 Touch RAM Replacement, Remove the RAM: stap 5, afbeelding 1 van 3 Lenovo Y50 Touch RAM Replacement, Remove the RAM: stap 5, afbeelding 2 van 3 Lenovo Y50 Touch RAM Replacement, Remove the RAM: stap 5, afbeelding 3 van 3
    • Gently unplug the RAM from its port.
    • Do not bend or drop the RAM, as this can affect its function.
    • You can replace up to two RAM sticks for this laptop. Just repeat step 4 for the second RAM port.
    • Pay attention to the arrangement of the pins on the RAM. When replacing the RAM, make sure the pins line up with the pins on the RAM port.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
9 andere personen hebben deze handleiding voltooid.
Andrew Tran
820 Reputatie
2 handleidingen geschreven
Cal Poly, Team 18-1, Maness Winter 2015 Lid van Cal Poly, Team 18-1, Maness Winter 2015
CPSU-MANESS-W15S18G1
5 Leden
15 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 36
Altijd: 5,825
