Inleiding
The wireless local area network (WLAN) card, or Wi-Fi card, is an essential component for laptops to establish and maintain wireless connectivity for internet access. The following symptoms can be signs of a failing or faulty Wi-Fi card:
- Can’t connect to the internet
- Connected to the router but no internet
- My Wi-Fi address won’t show up
- Wi-Fi connection keeps dropping
If your Lenovo ThinkPad T450 is experiencing any of the above symptoms, it may be time to replace the Wi-Fi card in your laptop. When you remove the back cover of the laptop to expose the inner components, the Wi-Fi card is typically fastened onto the motherboard by a single screw. Follow these simple instructions to replace the Wi-Fi card in your device.
Wat je nodig hebt
Using your hands, slide the two locking tabs away from each other to release the battery.
Slide the battery up and out of the device.
Using the JIS #00 screwdriver, unscrew seven screws from the back cover.
Use the JIS #00 screwdriver to remove the single 2.8 mm screw from the back cover.
Lift and remove the black piece of plastic to expose the Wi-Fi card.
