Inleiding
If the Lenovo ThinkPad Yoga 11e Gen 6 is having trouble connecting or staying connected to the Wi-Fi network, the Wi-Fi board may need to be replaced. The Wi-Fi board allows the device to connect to wireless networks. This guide will demonstrate the process of replacing this component.
Wat je nodig hebt
Disconnect the laptop from power and make sure it is completely powered off.
Turn the laptop facing down.
Loosen the eight captive screws using a JIS #0 screwdriver.
Use a spudger to release the tabs securing the back case and carefully remove the panel.
Push on alternating sides of the JST connector and pull straight away from the socket to disconnect the CMOS battery.
