Ga door naar hoofdinhoud
Lenovo ThinkPad X280 Speaker Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad X280 Speaker Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • To begin, ensure that the device is completely powered off and not connected to an energy supply.
    • Close the device and flip it over to expose the back panel.
  2. Lenovo ThinkPad X280 Speaker Replacement: stap 2, afbeelding 1 van 2 Lenovo ThinkPad X280 Speaker Replacement: stap 2, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to unscrew the five captive screws on the back panel until a small pop is heard.
    • These are captive screws and do not come out completely.
  3. Lenovo ThinkPad X280 Speaker Replacement: stap 3, afbeelding 1 van 2 Lenovo ThinkPad X280 Speaker Replacement: stap 3, afbeelding 2 van 2
    • Gently wedge an opening tool or spudger under the back panel, and loosen the clips around the perimeter until the back panel comes off.
    • Remove the back cover.
  4. Lenovo ThinkPad X280 Speaker Replacement, Battery: stap 4, afbeelding 1 van 3 Lenovo ThinkPad X280 Speaker Replacement, Battery: stap 4, afbeelding 2 van 3 Lenovo ThinkPad X280 Speaker Replacement, Battery: stap 4, afbeelding 3 van 3
    • Using the Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery down.
    • Remove the battery.
  5. Lenovo ThinkPad X280 Speaker Replacement, Speakers: stap 5, afbeelding 1 van 3 Lenovo ThinkPad X280 Speaker Replacement, Speakers: stap 5, afbeelding 2 van 3 Lenovo ThinkPad X280 Speaker Replacement, Speakers: stap 5, afbeelding 3 van 3
    • Using a Phillips #1 screwdriver, remove two 5 mm screws from each speaker.
    • Once done, the speakers should still be attached with a red wire connecting to each other.
  6. Lenovo ThinkPad X280 Speaker Replacement: stap 6, afbeelding 1 van 2 Lenovo ThinkPad X280 Speaker Replacement: stap 6, afbeelding 2 van 2
    • Using the black spudger, push the white plastic connector out of the the tan plug.
  7. Lenovo ThinkPad X280 Speaker Replacement: stap 7, afbeelding 1 van 1
    • Remove speakers and wiring from device.
Conclusie
Jordan Wooten
594 Reputatie
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 32
Altijd: 1,392
