Ga door naar hoofdinhoud
Lenovo ThinkPad X280 Fingerprint Scanner Replacement
Wat je nodig hebt
    1. Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Back Panel: stap 1, afbeelding 1 van 1
      • To begin, ensure that the device is completely powered off and not connected to an energy supply.
      • Close the device and flip it over to expose the back panel.
      Vraag FixBot
      Voeg opmerking toe
    2. Lenovo ThinkPad X280  Fingerprint Scanner Replacement: stap 2, afbeelding 1 van 2 Lenovo ThinkPad X280  Fingerprint Scanner Replacement: stap 2, afbeelding 2 van 2
      • Use a Phillips #1 screwdriver to unscrew the five captive screws on the back panel until a small pop is heard.
      • These are captive screws and do not come out completely.
      Vraag FixBot
      Voeg opmerking toe
    3. Lenovo ThinkPad X280  Fingerprint Scanner Replacement: stap 3, afbeelding 1 van 2 Lenovo ThinkPad X280  Fingerprint Scanner Replacement: stap 3, afbeelding 2 van 2
      • Gently wedge an opening tool or spudger under the back panel, and loosen the clips around the perimeter until the back panel comes off.
      • Remove the back cover.
      Vraag FixBot
      Voeg opmerking toe
    1. Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Battery: stap 4, afbeelding 1 van 3 Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Battery: stap 4, afbeelding 2 van 3 Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Battery: stap 4, afbeelding 3 van 3
      • Using the Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery down.
      • Remove the battery.
      Vraag FixBot
      Voeg opmerking toe
    1. Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Fingerprint Scanner: stap 5, afbeelding 1 van 3 Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Fingerprint Scanner: stap 5, afbeelding 2 van 3 Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Fingerprint Scanner: stap 5, afbeelding 3 van 3
      • Using a Phillips #1 screwdriver, remove one 5 mm screw from the fingerprint sensor.
      • Remove the metal plate covering the sensor.
      Vraag FixBot
      Voeg opmerking toe
    2. Lenovo ThinkPad X280  Fingerprint Scanner Replacement: stap 6, afbeelding 1 van 2 Lenovo ThinkPad X280  Fingerprint Scanner Replacement: stap 6, afbeelding 2 van 2
      • Using the black spudger tool, flip up the small hinged locking flap connected to the motherboard.
      • Gently pull the cable out of the connection site.
      Vraag FixBot
      Voeg opmerking toe
    3. Lenovo ThinkPad X280  Fingerprint Scanner Replacement: stap 7, afbeelding 1 van 1
      • Remove fingerprint scanner and metal covering from device.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Jordan Wooten
636 Reputatie
4 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 23
Altijd: 1,929
