Ga door naar hoofdinhoud
Lenovo ThinkPad X140e Keyboard Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad X140e Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Set the laptop facing you with the screen open.
    Vraag FixBot
    Voeg opmerking toe
  2. Lenovo ThinkPad X140e Keyboard Replacement: stap 2, afbeelding 1 van 2 Lenovo ThinkPad X140e Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Using a small plastic opening tool, pry off the keyboard starting at a point closest to you and working around the perimeter.
    Vraag FixBot
    Voeg opmerking toe
  3. Lenovo ThinkPad X140e Keyboard Replacement: stap 3, afbeelding 1 van 3 Lenovo ThinkPad X140e Keyboard Replacement: stap 3, afbeelding 2 van 3 Lenovo ThinkPad X140e Keyboard Replacement: stap 3, afbeelding 3 van 3
    • Flip up the ZIF connector that is holding the small ribbon cable in place.
    • Proceed to pull out the small ribbon cable
    Vraag FixBot
    Voeg opmerking toe
  4. Lenovo ThinkPad X140e Keyboard Replacement: stap 4, afbeelding 1 van 3 Lenovo ThinkPad X140e Keyboard Replacement: stap 4, afbeelding 2 van 3 Lenovo ThinkPad X140e Keyboard Replacement: stap 4, afbeelding 3 van 3
    • Flip up the ZIF connector that is holding the larger ribbon cable in place.
    • Proceed to pull out the large ribbon cable.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
kevin hull
219 Reputatie
2 handleidingen geschreven
Cal Poly, Team 20-5, Livingston Fall 2016 Lid van Cal Poly, Team 20-5, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G5
4 Leden
5 handleidingen geschreven
4Gids Commentaar
how can I buy a keyboard for my lenovo thinkpad x140e laptop?
Bryan - Antwoord Deel
The keyboard for the X140e is the same as the one for the X130e and the X131e and the X121e.
It is FRU 04y0379
Buy the keyboard on eBay.
atexit8 - Antwoord Deel
Just as a note, there are two screws that keep that keyboard held in place. You need to remove the back panel and take out those two screws, otherwise you’re going to have a tough time. Also, you really don’t need the pry tool, once those screws are out, the keyboard slides off. The rest of the process is spot on.
Jeffrey Chocklette - Antwoord Deel
Don’t forget the screws, otherwise you will never get the keyboard off or worse damage it during removal
celticxxtwin - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 45
Altijd: 2,281
