Ga door naar hoofdinhoud
Lenovo ThinkPad X100e Screen Replacement
Wat je nodig hebt
    1. Lenovo ThinkPad X100e Screen Replacement, Screen: stap 1, afbeelding 1 van 2 Lenovo ThinkPad X100e Screen Replacement, Screen: stap 1, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      Spudger
      $2.99
      • Use a Spudger tool to remove the screw covers on each side of the screen.
      • Be sure not to lose screw covers.
      Vraag FixBot
      Voeg opmerking toe
    2. Lenovo ThinkPad X100e Screen Replacement: stap 2, afbeelding 1 van 1
      • Using a magnetic screwdriver fit with a PH0 Bit, unscrew the two screws and carefully set the aside.
      Vraag FixBot
      Voeg opmerking toe
    3. Lenovo ThinkPad X100e Screen Replacement: stap 3, afbeelding 1 van 1
      • Pry open the bezel carefully with the spudger tool.
      • You will want to do this until the frame is completely off.
      Vraag FixBot
      Voeg opmerking toe
    4. Lenovo ThinkPad X100e Screen Replacement: stap 4, afbeelding 1 van 1
      • Remove all exposed screws and carefully set them aside. There should be 6 visible screws.
      • Be sure to set the screws aside on the magnetic mat.
      Vraag FixBot
      Voeg opmerking toe
    5. Lenovo ThinkPad X100e Screen Replacement: stap 5, afbeelding 1 van 1
      • Lift the screen up carefully, and remove the screws on both sides of the panel. There should be 4 screws.
      • The other two screws are located in the exact place on the other side.
      • Don't forget to place the screws on the magnetic mat, separate from other screws.
      Vraag FixBot
      Voeg opmerking toe
    6. Lenovo ThinkPad X100e Screen Replacement: stap 6, afbeelding 1 van 2 Lenovo ThinkPad X100e Screen Replacement: stap 6, afbeelding 2 van 2
      • Remove the connector located at the very top of the screen beside the webcam.
      • To remove the connector, simply pull the connector out.
      Vraag FixBot
      Voeg opmerking toe
    7. Lenovo ThinkPad X100e Screen Replacement: stap 7, afbeelding 1 van 1
      • Fold the panel over until a strip of black tape is visible.
      • Peel the tape down until you get to the base.
      Vraag FixBot
      Voeg opmerking toe
    8. Lenovo ThinkPad X100e Screen Replacement: stap 8, afbeelding 1 van 2 Lenovo ThinkPad X100e Screen Replacement: stap 8, afbeelding 2 van 2
      • Peel the piece of transparent tape back.
      • At this point there should be some exposed wires underneath the tape.
      Vraag FixBot
      Voeg opmerking toe
    9. Lenovo ThinkPad X100e Screen Replacement: stap 9, afbeelding 1 van 1
      • Remove the connector carefully with the spudger tool.
      Vraag FixBot
      Voeg opmerking toe
    10. Lenovo ThinkPad X100e Screen Replacement: stap 10, afbeelding 1 van 1
      • Remove the black tape fully.
      • Now your device is ready for a new panel.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Orly Guerra
448 Reputatie
2 handleidingen geschreven
1Gids Commentaar
What can be used as a replacement screen, as it's listed not for sale?
Keith Bowe - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 32
Altijd: 1,340
