Ga door naar hoofdinhoud
Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Ensure the laptop is powered off and the charging cable is disconnected before opening the back cover.
    • Flip over the laptop to access the back cover.
  2. Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement: stap 2, afbeelding 1 van 2 Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement: stap 2, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver to remove the eight 8 mm screws.
    More pricesely, screws need to be unscrewed, but not removed, since they stay attached to the back cover. Trying to remove them may damage the small gaskets around the screw shaft.
    Edouard Rossignol - Antwoord
  3. Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement: stap 3, afbeelding 1 van 1
    • Remove the back cover.
    • A popping sound may occur when the back cover is removed.
    Good solution, but where do I find the battery?
    Brian Arnold - Antwoord
  4. Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement, SSD: stap 4, afbeelding 1 van 1
    • Use a Phillips #0 screwdriver to remove one 6 mm screw.
  5. Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement: stap 5, afbeelding 1 van 2 Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement: stap 5, afbeelding 2 van 2
    • Slide the SSD out of the shiny covering.
    • Remove the SSD.
Conclusie
9 andere personen hebben deze handleiding voltooid.
Ashley Haraguchi
599 Reputatie
4 handleidingen geschreven
Cal Poly, Team S22-G3, Regan Winter 2020 Lid van Cal Poly, Team S22-G3, Regan Winter 2020
CPSU-REGAN-W20S22G3
5 Leden
7 handleidingen geschreven
1Gids Commentaar
What kind of SSD is this compatible with? There are several different connector standards…
Shai Revzen - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 96
Altijd: 8,141
