Ga door naar hoofdinhoud
Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement, Wireless Adapter: stap 1, afbeelding 1 van 2 Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement, Wireless Adapter: stap 1, afbeelding 2 van 2
    • Orient the laptop so that it is bottom up, and the track pad is closet to you.
    • Unscrew the seven cover screws with a Phillips #00 head screwdriver. These screws will loosen but will stay attached to the cover.
    • Slide the blue opening pick along the side of the laptop and pry off the one clip on each side.
  2. Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement: stap 2, afbeelding 1 van 2 Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement: stap 2, afbeelding 2 van 2
    • Using a Phillips #00 head screwdriver, remove the 3mm screw holding the wireless adapter to the motherboard.
  3. Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement: stap 3, afbeelding 1 van 3 Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement: stap 3, afbeelding 2 van 3 Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement: stap 3, afbeelding 3 van 3
    • Slide the chip to the right carefully until the wireless adapter pops out.
    • Disconnect the grey and black wires by lifting them off straight up until they pop off the wireless adapter.
    • The chip should be completely removed from the computer and you are done.
Conclusie
Beckham Richmond
467 Reputatie
3 handleidingen geschreven
Cal Poly, Team S7-G3, Regan Winter 2020 Lid van Cal Poly, Team S7-G3, Regan Winter 2020
CPSU-REGAN-W20S7G3
4 Leden
8 handleidingen geschreven
Één opmerking
Hi, does the Lenovo X1 Extreme Gen 1 support Wifi 6 or 6e? If so what which card?
I tried the:
"AX210NGW WiFi Card, Wi-Fi 6E 11AX Wireless Module Expand to 6GHz MU-MIMO Tri-Band Bluetooth 5.3 Internal Network Adapter for Laptop, Support Windows 10/11 64bit, M.2/NGFF"
Wifi worked but Bluetooth wasn't recognized.
Captainturk - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 47
Altijd: 1,958
