Ga door naar hoofdinhoud
Lenovo ThinkPad T560 Fan Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad T560 Fan Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Before you begin this guide, make sure to disable the internal battery, power down the device and disconnect from any external power sources.
    • The external battery should be removed prior to back panel disassembly however this device doesn't have one so we aren't able to show the process.
    • Using the Phillips #0 screwdriver, remove the eight 7 mm screws holding the back panel to the T560.
  2. Lenovo ThinkPad T560 Fan Replacement: stap 2, afbeelding 1 van 1
    • Use the iFixit opening tool to pry the back panel off your T560.
    • Work your way around the perimeter of the device to undo the clips and detach the back panel.
  3. Lenovo ThinkPad T560 Fan Replacement, Battery: stap 3, afbeelding 1 van 2 Lenovo ThinkPad T560 Fan Replacement, Battery: stap 3, afbeelding 2 van 2
    • Disconnect the battery connector from the motherboard by pulling it out of the port.
  4. Lenovo ThinkPad T560 Fan Replacement: stap 4, afbeelding 1 van 1
    • Using the Phillips #0 screwdriver, remove the five 3.5 mm screws securing the battery.
    • Remove the battery.
  5. Lenovo ThinkPad T560 Fan Replacement, Fan: stap 5, afbeelding 1 van 3 Lenovo ThinkPad T560 Fan Replacement, Fan: stap 5, afbeelding 2 van 3 Lenovo ThinkPad T560 Fan Replacement, Fan: stap 5, afbeelding 3 van 3
    • Using the iFixit opening tool, unlatch the power button's connection to the motherboard.
    • Remove the ribbon cable from the connector.
  6. Lenovo ThinkPad T560 Fan Replacement: stap 6, afbeelding 1 van 1
    • Unplug the fan from the motherboard.
  7. Lenovo ThinkPad T560 Fan Replacement: stap 7, afbeelding 1 van 1
    • Using the Phillips #0 screwdriver, remove the four 3.5 mm screws securing the heatsink.
  8. Lenovo ThinkPad T560 Fan Replacement: stap 8, afbeelding 1 van 1
    • Using the Phillips #0 screwdriver, unscrew the 3.5mm screw securing the fan to the case.
    • Remove the fan and conjoined heatsink.
Conclusie
Jackson Reynolds
517 Reputatie
5 handleidingen geschreven
Clemson, Team 1-3, Hunter Spring 2022 Lid van Clemson, Team 1-3, Hunter Spring 2022
CLEM-HUNTER-S22S1G3
5 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 28
Altijd: 809
