Ga door naar hoofdinhoud
Lenovo ThinkPad T560 Back Panel Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad T560 Back Panel Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Before you begin this guide, make sure to disable the internal battery, power down the device and disconnect from any external power sources.
    • The external battery should be removed prior to back panel disassembly however this device doesn't have one so we aren't able to show the process.
    • Using the Phillips #0 screwdriver, remove the eight 7 mm screws holding the back panel to the T560.
    Vraag FixBot
    Voeg opmerking toe
  2. Lenovo ThinkPad T560 Back Panel Replacement: stap 2, afbeelding 1 van 1
    • Use the iFixit opening tool to pry the back panel off your T560.
    • Work your way around the perimeter of the device to undo the clips and detach the back panel.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Jackson Reynolds
517 Reputatie
5 handleidingen geschreven
Clemson, Team 1-3, Hunter Spring 2022 Lid van Clemson, Team 1-3, Hunter Spring 2022
CLEM-HUNTER-S22S1G3
5 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 48
Altijd: 1,708
