Ga door naar hoofdinhoud
Lenovo ThinkPad T431S Screen Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad T431S Screen Replacement, Screen: stap 1, afbeelding 1 van 2 Lenovo ThinkPad T431S Screen Replacement, Screen: stap 1, afbeelding 2 van 2
    • Remember before starting any disassembly, to prevent electric shock or harm, disconnect from any external power source and make sure device is powered off.
    • Use the Jimmy tool to remove the screen bezel with a gentle prying motion.
  2. Lenovo ThinkPad T431S Screen Replacement: stap 2, afbeelding 1 van 2 Lenovo ThinkPad T431S Screen Replacement: stap 2, afbeelding 2 van 2
    • Remove the four 3.0 mm screws in the four corners of the screen with a Phillips #1 screwdriver bit.
    • While removing the screws, pry the screen off with an opening tool.
    • If your screen is cracked, use caution, as there will be broken glass or sharp parts.
  3. Lenovo ThinkPad T431S Screen Replacement: stap 3, afbeelding 1 van 3 Lenovo ThinkPad T431S Screen Replacement: stap 3, afbeelding 2 van 3 Lenovo ThinkPad T431S Screen Replacement: stap 3, afbeelding 3 van 3
    • Lift screen off of top panel to reveal LCD power plug/connector.
    • There will be a wire attaching the screen to the rest of the device.
    • Remove the tape on the wire so you can unplug the connection, pulling upwards.
    • Information about disposal of your damaged screen can be found at E-Waste Recycling
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 21
Altijd: 986
