Ga door naar hoofdinhoud
Lenovo ThinkPad T431S Battery Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad T431S Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Lenovo ThinkPad T431S Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Remember, to prevent electric shock or harm, disconnect the laptop from any external power source and make sure device is powered off before starting any disassembly.
    • Use a Phillips #1 screwdriver bit to remove the eight 5mm screws from the back panel.
    • Once the screws are loose, use the three opening tools to loosen and remove the back panel.
  2. Lenovo ThinkPad T431S Battery Replacement: stap 2, afbeelding 1 van 3 Lenovo ThinkPad T431S Battery Replacement: stap 2, afbeelding 2 van 3 Lenovo ThinkPad T431S Battery Replacement: stap 2, afbeelding 3 van 3
    • Carefully unplug the battery cable from the connector on the motherboard, using your fingers to pull the cable straight out of the port.
  3. Lenovo ThinkPad T431S Battery Replacement: stap 3, afbeelding 1 van 3 Lenovo ThinkPad T431S Battery Replacement: stap 3, afbeelding 2 van 3 Lenovo ThinkPad T431S Battery Replacement: stap 3, afbeelding 3 van 3
    • Unscrew the five 4mm screws that are holding the battery secure with a Phillips #1 screwdriver.
    • Remove the Li-polymer battery by lifting it directly out of the device.
    • Information about disposal of your damaged battery can be found at E-Waste Recycling
Conclusie
3 andere personen hebben deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 20
Altijd: 1,275
