Ga door naar hoofdinhoud
Lenovo N23 Yoga Keyboard Replacement
Wat je nodig hebt
  1. Lenovo N23 Yoga Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 3 Lenovo N23 Yoga Keyboard Replacement, Keyboard: stap 1, afbeelding 2 van 3 Lenovo N23 Yoga Keyboard Replacement, Keyboard: stap 1, afbeelding 3 van 3
    • Flip the computer over.
    • Remove the 9 screws surrounding the edges of the computer.
    • Remove the single screw near the center of the computer.
  2. Lenovo N23 Yoga Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Use a smaller plastic panel popping tool to begin (if you have one). You may increase to a larger size as you go (if you have one)
    • Slowly work your way around the edges of the computer.
    • Closer to the screen the clips will be sturdier, use a little more force but still be cautious.
  3. Lenovo N23 Yoga Keyboard Replacement: stap 3, afbeelding 1 van 1
    • On the main board, lift up on the black tabs of the connectors that are connected to the ribbons.
    • Remove the ribbon connectors gently from the main board.
  4. Lenovo N23 Yoga Keyboard Replacement: stap 4, afbeelding 1 van 1
    • The keyboard should be free and disconnected from the rest of the computer.
Conclusie
Drew Canada
1.433 Reputatie
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 8
Altijd: 1,628
