Ga door naar hoofdinhoud
Lenovo Legion Y520-15IKBN I/O Board Replacement
Wat je nodig hebt
  1. Lenovo Legion Y520-15IKBN I/O Board Replacement, Hard Drive: stap 1, afbeelding 1 van 2 Lenovo Legion Y520-15IKBN I/O Board Replacement, Hard Drive: stap 1, afbeelding 2 van 2
    • Remove the thirteen 6.5 mm screws from the bottom of the laptop using a Phillips #00 screwdriver.
  2. Lenovo Legion Y520-15IKBN I/O Board Replacement: stap 2, afbeelding 1 van 1
    • Flip the laptop on its side and use a spudger or a credit card to pry the bottom covering off. To get a better grip you may want to open the laptop slightly.
    • The bottom piece will make popping noises as it is pulled from the laptop.
    • When reassembling make sure that the bottom piece clicks back into place on all sides of the laptop.
  3. Lenovo Legion Y520-15IKBN I/O Board Replacement: stap 3, afbeelding 1 van 3 Lenovo Legion Y520-15IKBN I/O Board Replacement: stap 3, afbeelding 2 van 3 Lenovo Legion Y520-15IKBN I/O Board Replacement: stap 3, afbeelding 3 van 3
    • The hard drive is a white square located on the right side of your device.
    • Use a Phillips #00 screwdriver to remove four 4.0 mm screws holding the hard drive in place.
  4. Lenovo Legion Y520-15IKBN I/O Board Replacement: stap 4, afbeelding 1 van 2 Lenovo Legion Y520-15IKBN I/O Board Replacement: stap 4, afbeelding 2 van 2
    • Slide the hard drive from the device towards your right.
    • When reinstalling remember to slide the hard drive in from the right. Don't try to force it in from the front.
  5. Lenovo Legion Y520-15IKBN I/O Board Replacement, I/O Board: stap 5, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the three 6.5 mm screws that secure the I/O board.
  6. Lenovo Legion Y520-15IKBN I/O Board Replacement: stap 6, afbeelding 1 van 1
    • Use the point of a spudger to push on alternating sides of the CMOS connector to "walk" it out of its socket.
    • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
    • To reconnect the cable, align the connector and use a spudger or clean fingernail to push it fully into the socket.
    • Don't push on the cables themselves, or you may damage the connector.
    • Slide the I/O board out from edge of the laptop to remove it.
    • The CMOS battery was also removed with the I/O board in this photo. It is held on with a small amount of adhesive. It is not necessary to remove the CMOS battery for this repair.
Conclusie
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
RobbyT
85 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 14
Altijd: 38
