Ga door naar hoofdinhoud
Lenovo Legion Y520-15IKBN Heatsink Replacement
Wat je nodig hebt
  1. Lenovo Legion Y520-15IKBN Heatsink Replacement, Base Panel: stap 1, afbeelding 1 van 2 Lenovo Legion Y520-15IKBN Heatsink Replacement, Base Panel: stap 1, afbeelding 2 van 2
    • Shut down and unplug your device before proceeding.
    • Remove the thirteen 6.5 mm screws from the base plate using a Phillips #00 screwdriver.
  2. Lenovo Legion Y520-15IKBN Heatsink Replacement: stap 2, afbeelding 1 van 1
    • Flip the laptop on its side and wedge a spudger between the base panel and chassis, then pry around the perimeter until the base panel releases.
    • To get a better grip you may want to open the laptop slightly.
    • Lift the bottom panel off of the chassis.
    • During reassembly, make sure that the bottom panel clicks back into place on all four sides of the laptop.
  3. Lenovo Legion Y520-15IKBN Heatsink Replacement, Fan: stap 3, afbeelding 1 van 3 Lenovo Legion Y520-15IKBN Heatsink Replacement, Fan: stap 3, afbeelding 2 van 3 Lenovo Legion Y520-15IKBN Heatsink Replacement, Fan: stap 3, afbeelding 3 van 3
    • There is a piece of plastic covering part of the RAM and the fan. You will need to remove this to get to the fan.
    • Unplug the battery then, you will need to remove the four 4 mm screws around the fan using a Phillips #00 screwdriver.
  4. Lenovo Legion Y520-15IKBN Heatsink Replacement: stap 4, afbeelding 1 van 3 Lenovo Legion Y520-15IKBN Heatsink Replacement: stap 4, afbeelding 2 van 3 Lenovo Legion Y520-15IKBN Heatsink Replacement: stap 4, afbeelding 3 van 3
    • Unscrew all the screws then unplug the wires connected to the fan.
    • Once all the wires are unplugged from the fan, move the wires aside to get the fan.
  5. Lenovo Legion Y520-15IKBN Heatsink Replacement: stap 5, afbeelding 1 van 3 Lenovo Legion Y520-15IKBN Heatsink Replacement: stap 5, afbeelding 2 van 3 Lenovo Legion Y520-15IKBN Heatsink Replacement: stap 5, afbeelding 3 van 3
    • Lift the fan out of the laptop body.
  6. Lenovo Legion Y520-15IKBN Heatsink Replacement, Heatsink: stap 6, afbeelding 1 van 2 Lenovo Legion Y520-15IKBN Heatsink Replacement, Heatsink: stap 6, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove the five 6.5 mm screws securing the heat sink.
  7. Lenovo Legion Y520-15IKBN Heatsink Replacement: stap 7, afbeelding 1 van 2 Lenovo Legion Y520-15IKBN Heatsink Replacement: stap 7, afbeelding 2 van 2
    • Use a spudger to gently pry the heatsink from the board.
Conclusie
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Uriel Meneses
85 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 27
Altijd: 60
