Ga door naar hoofdinhoud
Lenovo IdeaPad Flex 5-1570 Webcam Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad Flex 5-1570 Webcam Replacement, Back Panel: stap 1, afbeelding 1 van 2 Lenovo IdeaPad Flex 5-1570 Webcam Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 2, afbeelding 1 van 3 Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 2, afbeelding 2 van 3 Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 2, afbeelding 3 van 3
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 3, afbeelding 1 van 2 Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 3, afbeelding 2 van 2
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5-1570 Webcam Replacement, Battery: stap 4, afbeelding 1 van 2 Lenovo IdeaPad Flex 5-1570 Webcam Replacement, Battery: stap 4, afbeelding 2 van 2
    • Remove the two 5 mm Phillips #00 screws that secure the battery in place.
  5. Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 5, afbeelding 1 van 3 Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 5, afbeelding 2 van 3 Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 5, afbeelding 3 van 3
    • Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard.
    • Be sure to apply even pressure across the wires and connector to not damage the battery cable.
    • Remove the battery from the device.
  6. Lenovo IdeaPad Flex 5-1570 Webcam Replacement, Hard Drive: stap 6, afbeelding 1 van 1
    • Remove the three 5 mm Phillips #00 screws that secure the hard drive.
  7. Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 7, afbeelding 1 van 2 Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 7, afbeelding 2 van 2
    • Using your hands, gently pull the hard drive back, sliding it out from the port.
  8. Lenovo IdeaPad Flex 5-1570 Webcam Replacement, Fan: stap 8, afbeelding 1 van 1
    • Remove the two 5 mm Phillips #00 screws that secure the fan in place.
  9. Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 9, afbeelding 1 van 1
    • Using your hands, remove the wire that is wrapped around the base of the fan.
  10. Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 10, afbeelding 1 van 2 Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 10, afbeelding 2 van 2
    • Disconnect the wire holding the fan and the motherboard together.
    • Remove the fan from the device.
  11. Lenovo IdeaPad Flex 5-1570 Webcam Replacement, Heatsink: stap 11, afbeelding 1 van 1
  12. Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 12, afbeelding 1 van 2 Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 12, afbeelding 2 van 2
    • Carefully remove the heatsink from the device.
    • During reassembly, don't forget to apply thermal paste onto the heatsink. For proper technique on thermal paste application, please visit the How to Apply Thermal Paste guide.
  13. Lenovo IdeaPad Flex 5-1570 Webcam Replacement, Speakers: stap 13, afbeelding 1 van 3 Lenovo IdeaPad Flex 5-1570 Webcam Replacement, Speakers: stap 13, afbeelding 2 van 3 Lenovo IdeaPad Flex 5-1570 Webcam Replacement, Speakers: stap 13, afbeelding 3 van 3
    • Using the iFixit nylon tipped tweezers, disconnect the wire that connects the speakers to the motherboard.
  14. Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 14, afbeelding 1 van 2 Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 14, afbeelding 2 van 2
    • Using your hands, gently pull the left speaker up and out of the device.
  15. Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 15, afbeelding 1 van 2 Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 15, afbeelding 2 van 2
    • Repeat the previous step for the other speaker and remove the speakers from the device.
  16. Lenovo IdeaPad Flex 5-1570 Webcam Replacement, Motherboard: stap 16, afbeelding 1 van 1
    • Using the Phillips #00 screwdriver, remove the three 5 mm Phillips #00 screws securing the motherboard.
  17. Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 17, afbeelding 1 van 2 Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 17, afbeelding 2 van 2
    • Disconnect the auxiliary port cable from the motherboard.
  18. Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 18, afbeelding 1 van 3 Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 18, afbeelding 2 van 3 Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 18, afbeelding 3 van 3
    • Using a plastic opening tool, unlock the four ZIF connectors of the flat cables.
    • Lift up the connector locking tab and disconnect the cables from the motherboard.
  19. Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 19, afbeelding 1 van 2 Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 19, afbeelding 2 van 2
    • Disconnect the display cable from the motherboard.
  20. Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 20, afbeelding 1 van 2 Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 20, afbeelding 2 van 2
    • Using the plastic opening tool, unlock the connector for the side ports panel and disconnect the cable from the motherboard.
  21. Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 21, afbeelding 1 van 2 Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 21, afbeelding 2 van 2
    • Carefully lift and remove the motherboard from the device.
  22. Lenovo IdeaPad Flex 5-1570 Webcam Replacement, Display Assembly: stap 22, afbeelding 1 van 2 Lenovo IdeaPad Flex 5-1570 Webcam Replacement, Display Assembly: stap 22, afbeelding 2 van 2
    • Using the Phillips #00 screwdriver, remove the four total 5 mm screws from the left and right hinges (two screws on each hinge).
    • For proper screwdriver technique, please visit the Screwdriver Best Practices guide.
  23. Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 23, afbeelding 1 van 2 Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 23, afbeelding 2 van 2
    • Disconnect the display assembly from the rest of the device.
  24. Lenovo IdeaPad Flex 5-1570 Webcam Replacement, Display: stap 24, afbeelding 1 van 3 Lenovo IdeaPad Flex 5-1570 Webcam Replacement, Display: stap 24, afbeelding 2 van 3 Lenovo IdeaPad Flex 5-1570 Webcam Replacement, Display: stap 24, afbeelding 3 van 3
    • Flip the display assembly so that the screen is facing you.
    • Using a spudger, remove the screw cover to expose two screws. Repeat this step for the cover on the right side of the screen.
    • The spudger may not provide enough prying power to remove the screw covers. If need be, carefully use the metal spudger to complete this step.
  25. Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 25, afbeelding 1 van 2 Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 25, afbeelding 2 van 2
    • Using the Phillips #00 screwdriver, remove the two 3 mm screws from the display (one screw on each side).
  26. Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 26, afbeelding 1 van 3 Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 26, afbeelding 2 van 3 Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 26, afbeelding 3 van 3
    • Using the opening picks and a plastic opening tool, remove the middle screw cover at the bottom of the display assembly to expose three screws.
    • Using the plastic opening picks and tools may not provide enough prying power. If need be, use the metal spudger to remove the screw covers.
    • Use the Phillips #00 screwdriver to remove three 3mm screws from the display assembly.
  27. Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 27, afbeelding 1 van 2 Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 27, afbeelding 2 van 2
    • Carefully insert the opening picks into the edge of the display and display cover.
    • Work your way around the screen to remove it from the assembly.
    • You may want to use a heat gun or hair dryer to heat up the adhesive holding the screen to the rest of the display assembly. These adhesive strips are located approximately 2 cm away from left and right edges of the screen and 3 cm from the top. This video shows where these strips are located.
    • Alternatively, using the iOpener may heat up the adhesive enough to remove the screen from the rest of the display. Please visit the iOpener Instructions guide for more details on properly heating the iOpener.
  28. Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 28, afbeelding 1 van 2 Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 28, afbeelding 2 van 2
    • Lift the screen up and away from the rest of the display assembly.
    • As stated in the previous step, there are two strong adhesive strips holding the screen to the rest of the display assembly, so please proceed with caution when separating the screen from the assembly.
  29. Lenovo IdeaPad Flex 5-1570 Webcam Replacement, Webcam: stap 29, afbeelding 1 van 3 Lenovo IdeaPad Flex 5-1570 Webcam Replacement, Webcam: stap 29, afbeelding 2 van 3 Lenovo IdeaPad Flex 5-1570 Webcam Replacement, Webcam: stap 29, afbeelding 3 van 3
    • Flip the screen over so that the backside of the screen is facing you.
    • Remove the tape covering the webcam and disconnect the webcam from the screen.
    • Unravel the cables along the left and right sides of the screen.
  30. Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 30, afbeelding 1 van 1
    • Using a spudger, remove the yellow tape on the bottom right corner of the screen.
  31. Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 31, afbeelding 1 van 1
    • Remove the yellow tape using your fingers or a plastic opening tool.
  32. Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 32, afbeelding 1 van 1
    • Using the plastic opening tool, remove the black tape from the device.
  33. Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 33, afbeelding 1 van 2 Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 33, afbeelding 2 van 2
    • Using the same tool, unlock the ZIF connectors and disconnect the flat cables.
  34. Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 34, afbeelding 1 van 2 Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 34, afbeelding 2 van 2
    • Using the plastic opening tool, disconnect the cable from panel.
  35. Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 35, afbeelding 1 van 3 Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 35, afbeelding 2 van 3 Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 35, afbeelding 3 van 3
    • Use the plastic opening tool to get under the piece of tape connecting the webcam cable to the display assembly.
    • Grip the piece of tape with your fingers and pull it away to disconnect the cable.
  36. Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 36, afbeelding 1 van 2 Lenovo IdeaPad Flex 5-1570 Webcam Replacement: stap 36, afbeelding 2 van 2
    • Disconnect the webcam and remove it from the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Justin Ogihara
27.167 Reputatie
52 handleidingen geschreven
EDU Team Lid van EDU Team
Staff
7 Leden
637 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 16
Altijd: 1,297
