Inleiding
The heatsink (or heat sink) is a passive heat exchanger that transfers heat in a device. The heatsink disperses heat from another component in the device to prevent the device from overheating.
If you find that your laptop easily overheats or is running at higher temperatures than normal, it may be time to replace the heatsink. Follow these simple instructions to remove and replace the heatsink in your Lenovo IdeaPad Flex 5-1570 laptop. Make sure to turn off your laptop and let it cool for 20 minutes before proceeding with the guide.
Don’t forget to follow our thermal paste application guide after you have removed your heat sink and are ready to reassemble your device.
Wat je nodig hebt
Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
Don’t forget to reapply thermal paste during reassembly. For proper technique on thermal paste application, please visit the How to Apply Thermal Paste guide.
Één andere persoon heeft deze handleiding voltooid.
