Ga door naar hoofdinhoud
Lenovo IdeaPad Flex 5-1570 Fan Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad Flex 5-1570 Fan Replacement, Back Panel: stap 1, afbeelding 1 van 2 Lenovo IdeaPad Flex 5-1570 Fan Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 Fan Replacement: stap 2, afbeelding 1 van 3 Lenovo IdeaPad Flex 5-1570 Fan Replacement: stap 2, afbeelding 2 van 3 Lenovo IdeaPad Flex 5-1570 Fan Replacement: stap 2, afbeelding 3 van 3
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 Fan Replacement: stap 3, afbeelding 1 van 2 Lenovo IdeaPad Flex 5-1570 Fan Replacement: stap 3, afbeelding 2 van 2
    • Once all the clips have been disengaged, lift off the back cover.
    You should probably disconnect the battery immediately after opening the laptop. Don’t want to risk damaging your nice hardware.
    Zack Colman - Antwoord
  4. Lenovo IdeaPad Flex 5-1570 Fan Replacement, Fan: stap 4, afbeelding 1 van 1
    • Remove the two 5 mm Phillips #00 screws that secure the fan in place.
  5. Lenovo IdeaPad Flex 5-1570 Fan Replacement: stap 5, afbeelding 1 van 1
    • Using your hands, remove the wire that is wrapped around the base of the fan.
  6. Lenovo IdeaPad Flex 5-1570 Fan Replacement: stap 6, afbeelding 1 van 2 Lenovo IdeaPad Flex 5-1570 Fan Replacement: stap 6, afbeelding 2 van 2
    • Disconnect the wire holding the fan and the motherboard together.
    • Remove the fan from the device.
Conclusie
Will Schafer
380 Reputatie
2 handleidingen geschreven
Cal Poly, Team S2-G6, White Winter 2020 Lid van Cal Poly, Team S2-G6, White Winter 2020
CPSU-WHITE-W20S2G6
4 Leden
13 handleidingen geschreven
Één opmerking
thank you for you share
Liu bing - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 42
Altijd: 2,370
