Ga door naar hoofdinhoud
Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement
Wat je nodig hebt
  1. Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement, Back Panel: stap 1, afbeelding 1 van 2 Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: stap 2, afbeelding 1 van 3 Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: stap 2, afbeelding 2 van 3 Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: stap 2, afbeelding 3 van 3
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: stap 3, afbeelding 1 van 2 Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: stap 3, afbeelding 2 van 2
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement, Battery: stap 4, afbeelding 1 van 2 Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement, Battery: stap 4, afbeelding 2 van 2
    • Remove the two 5 mm Phillips #00 screws that secure the battery in place.
  5. Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: stap 5, afbeelding 1 van 3 Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: stap 5, afbeelding 2 van 3 Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: stap 5, afbeelding 3 van 3
    • Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard.
    • Be sure to apply even pressure across the wires and connector to not damage the battery cable.
    • Remove the battery from the device.
  6. Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement, Daughterboard: stap 6, afbeelding 1 van 2 Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement, Daughterboard: stap 6, afbeelding 2 van 2
    • Using the plastic opening tool, unlock the connector for the side ports panel and disconnect the cable from the motherboard.
  7. Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: stap 7, afbeelding 1 van 2 Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: stap 7, afbeelding 2 van 2
    • Using the plastic opening tool, disconnect the CMOS battery from the daughterboard by pushing it out towards the direction of the CMOS battery.
  8. Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: stap 8, afbeelding 1 van 1
    • Using the Phillips #00 screwdriver, remove the single 5 mm screw.
  9. Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: stap 9, afbeelding 1 van 1
    • Using the iFixit Opening tool, remove the silver piece of tape from the device.
  10. Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: stap 10, afbeelding 1 van 2 Lenovo IdeaPad Flex 5-1570 Daughterboard Replacement: stap 10, afbeelding 2 van 2
    • Lift the daughterboard up and out of the device.
Conclusie
Justin Ogihara
27.236 Reputatie
52 handleidingen geschreven
EDU Team Lid van EDU Team
Staff
7 Leden
637 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 15
Altijd: 402
