Ga door naar hoofdinhoud
Lenovo Essential G570 Fan Replacement
Wat je nodig hebt
    1. Lenovo Essential G570 Fan Replacement, Battery: stap 1, afbeelding 1 van 1
      • Turn off the laptop.
      • Disconnect the charging cable.
      • Failure to unplug the cable could result in electric shock.
      • Turn the computer upside down.
      Vraag FixBot
      Voeg opmerking toe
    2. Lenovo Essential G570 Fan Replacement: stap 2, afbeelding 1 van 2 Lenovo Essential G570 Fan Replacement: stap 2, afbeelding 2 van 2
      • Locate the two switches that lock the battery.
      • Push the right switch outwards to unlock the battery.
      Vraag FixBot
      Voeg opmerking toe
    3. Lenovo Essential G570 Fan Replacement: stap 3, afbeelding 1 van 2 Lenovo Essential G570 Fan Replacement: stap 3, afbeelding 2 van 2
      • Push and hold the left switch outwards to unlock the battery.
      • Pull the battery away from the computer.
      Vraag FixBot
      Voeg opmerking toe
    1. Lenovo Essential G570 Fan Replacement, Back Panel: stap 4, afbeelding 1 van 1
      • Turn the laptop over so that the bottom side is facing up.
      Vraag FixBot
      Voeg opmerking toe
    2. Lenovo Essential G570 Fan Replacement: stap 5, afbeelding 1 van 1
      • Unscrew the five 5mm Phillips #0 screws that hold the cover in place.
      • The screws do not come out fully from the back plate. They stay attached to the plate itself.
      Vraag FixBot
      Voeg opmerking toe
    3. Lenovo Essential G570 Fan Replacement: stap 6, afbeelding 1 van 3 Lenovo Essential G570 Fan Replacement: stap 6, afbeelding 2 van 3 Lenovo Essential G570 Fan Replacement: stap 6, afbeelding 3 van 3
      • With the screws removed, insert the plastic opening tool into the groove located on the right side.
      • Begin to pry up, and the plate should lift up from the body of the laptop.
      • While lifting up, take the piece in one hand and pull up and to the right to fully remove the back plate.
      Vraag FixBot
      Voeg opmerking toe
    1. Lenovo Essential G570 Fan Replacement, Fan: stap 7, afbeelding 1 van 2 Lenovo Essential G570 Fan Replacement, Fan: stap 7, afbeelding 2 van 2
      • Carefully pull the fan's power connector from the laptop.
      Vraag FixBot
      Voeg opmerking toe
    2. Lenovo Essential G570 Fan Replacement: stap 8, afbeelding 1 van 2 Lenovo Essential G570 Fan Replacement: stap 8, afbeelding 2 van 2
      • Remove the three 5mm Phillips #1 screws holding the fan in place.
      Vraag FixBot
      Voeg opmerking toe
    3. Lenovo Essential G570 Fan Replacement: stap 9, afbeelding 1 van 2 Lenovo Essential G570 Fan Replacement: stap 9, afbeelding 2 van 2
      • Remove the fan by pulling it up and away from the computer.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Lucio
235 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S1-G1, Simcock Spring 2018 Lid van UMass Dartmouth, Team S1-G1, Simcock Spring 2018
UMASSD-SIMCOCK-S18S1G1
3 Leden
30 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 27
Altijd: 980
